Unitronic MK7 Golf R Downpipe @ BDTuning
Constructed of 3" T304 stainless steel mandrel bent tubing, T316 stainless steel flanges, a corrugated stainless steel flex section, and TIG welded fabrication, this downpipe is built to withstand the test of time, while performing to the max. All Unitronic downpipes come equipped with a 200-cell high flow metallic catalytic converter and all transitions are flow-matched to allow for maximum performance and airflow. In addition, Unitronic exhausts feature an easy-to-use v-band exhaust fastening system to ensure a fast and effortless installation and precise fitment. To finish it off, an OEM-inspired catalytic converter heat-sheild protects against unwanted heat radiating in the exhaust tunnel. Every Unitronic Exhaust System comes equipped with a brushed matte finish for an elegant appearance that will last a lifetime. There's simply nothing like it!
Limited stock is available so don't delay
$959.99 Inc free ground shipping to lower 48 States
Paypal Accepted
Paypal Accepted
Features
Direct bolt-on fitment with OEM mounting locations
80mm to 76.2mm turbo to downpipe transition
3-inch T304 stainless steel tubing
200-cell metallic matrix high-flow catalyst
Factory catalyst position for maximum efficiency
OEM-inspired catalytic converter heat shield to reduce radiant heat
Proper Oxygen sensor placement
Corrugated stainless steel flex section
TIG welded construction
Unique v-band fastening system featuring Clampco® clamps
PM or call us on 512 686 2776 to order
