ColinStone
- United Kingdom
- MKVII 2016 Match BM
Due to misorder, wrong part number, I have an unused aero undertray/stone/rubbish guard for FWD hatchback with multilink rear suspension - 1.4 TSI 122/125 2.0 TDI and higher spec cars. The part does not fit the basic beam axle car. Supplied with necessary fixings.
It fits on the passenger side just ahead of the rear wheel and covers the "hole" where the exhaust pipe is routed past the petrol tank. There is not one on the drivers side as the petrol tank is the undertray.
Can be seen in this post - www.golfmk7.com/forums/showthread.php?t=8532 Part III - Rear exhaust tray for 2WD Only.
While under the car it is worth fitting Part II - Front Exhaust Tunnel.
Item is in Oxford. Can post, panel is approx 2ft x 1ft but not that heavy.
Or can fit while u wait - 10 min job. If you get the other panel from your dealer, I'll fit that as well and provide the 4 rivet fixings required, or provide the 4 fixings for it with this one.
£13 plus postage, estimated at £4.
