So this driver's side coupler has blown off 3 times now. First time was on the factory pipe side, so I cinched it up better on that side. The last 2 times has been on the FMIC pipe side. I feel if the rubber coupler was just a touch longer, there would not be an issue. The other coupler/connection of this FMIC pipe is snug and seemingly connected as designed. However, it does have a bit of play, moving where the rubber coupler is. Clamps are secured very tight, in fact I feel if it was tighter that FMIC pipe would be getting crushed.
I've been driving slow and with the traction control on so I don't blow it off again until I find a better solution. I am running MAPerformance Stage 2 tune via Cobb.
Where can I find a longer coupler of this size at a reasonable cost? Any other thoughts?
