Gimpster
- Palm Bay, FL
- 2019 VW Golf R
My Curt trailer hitch should be delivered today (decided to go with them), so I'll snap some pictures when thats all done.
I installed the Curt 11564 hitch today. Fitment was very good, I did not have to clearance the rear crash bar in any way and I was able to use the foam without cutting it, and everything fit fine. No lower tab drama or anything like that. Happy for my $150.00 shipped.
It took about 90 minutes to install, some of that being me very slow pulling the bumper cover out of those plastic clips. The noise those make gives me anxiety.
What I was not happy about, and this isn't really Curts fault to a degree, are the rear blind spot sensors. The drivers side is A-OK, it has M8 captive washers/spacers you just slide the new longer bolts through. The passenger side is, ... I don't know what VW was thinking. It was almost like two different teams designed those sensor brackets. Instead of using the same M8 captive setup, they used M6. The M8 bolts that hold the crash bar on that side have M6 studs on top of them.
Curts solution is: you zip tie around the crash bar to hold it down. I did this for now, but going to try and find some longer M8 bolts with M6 studs eventually to make it "OEM". Really pained me to do that, even though nobody will ever see it. I would have gladly paid Curt to provide these bolts for a few bucks more. I attached some pictures of this situation, hopefully they are clear enough. My other compliant, and I've given this feedback to Curt before (I've owned like 5 of their hitches now) is their packaging... in a word... sucks. The hitch had busted through the box (like always), but thankfully was not hurt and the powder coating was intact.
The cut in the bumper was a total non-event, and even if you removed the hitch you'd never know it was there unless you had the car on a lift. I just marked it out 3.5" x 2.5" on the center line per the instructions and used a rotary tool.
I had space to keep a trailer, I'd do it too, even towing stuff to VW meets just for the fun of it.This is primarily for my UK friends that own a mk7.5 R. In the US, the manual states to not install a hitch and not tow with the R. Is that the same in the UK or are you allowed to tow small loads? I ask because I sold Showbox jiofi.local.html tplinklogin my primary car that I pulled a small 4ftx8ft utility trailer and now I have to tow it with my 128 BMW convertible. While this set up works fine, I'm not a fan of towing the trailer with the 'vert. So UK folks, are you allowed to tow or not? Just curious...
