JackRabbitSLIM
- OHIO
- MK7 GTI
https://www.ft86club.com/forums/showthread.php?t=91820Does anyone know how oil weight effect oil temps?
I am trying to find ways to keep my temps down without having to buy an oil cooler? I have been running the factory spec oil. Does a heavier weight help keep cool? Also, does running the heat really help much with coolant temps?
Oil thins as it gets hotter. Heavier oil helps keep the oil pressure up at higher temperatures. If you are going to do multiple track days per year, just buy a darn oil cooler! It's important. If you don't do many events, just monitor the temp and don't let it get too high...and change the oil often.
Turning the heat on lets the HVAC heat exchanger act like another (small) radiator. So it could help lower the water temp (a little), which could help keep the engine cooler resulting in slightly less oil temp. This is not a good solution, or a solution at all really...Over heating the driver is possibly the most dangerous thing you can do on track.
