Timing Chain Cover Leak
TheContender09
Golf R
so how did it go? im about to take my valve cover off to replace the sealant as im having a missfire in cylinder 3. i want to try and do this job myself and save some money. also do i need to replace the timing chain bolts that hold the cover on when i take off the cover?
anotero
Hither and thither
Mk7 GTI
Valve cover gasket replacement is not related to the timing chain cover gasket. The latter was straightforward, nothing out of the ordinary. Doing a valve cover gasket replacement yourself sounds intimidating. Good luck.
TheContender09
Golf R
Okay great! Thanks for the info 🙏
Mosquito
Any new DIY attempts on this?
Bottom bolts look a bit tight, but with the right tools it might be possible to do without taking out the motor mount.
Question is, do both bolts have enough clearance to fully come out once loose? Looks like a 10 mm wrench is the way to go on those two.
anotero
Hither and thither
Mk7 GTI
I did not remove the motor mount.
autovelocity
Canada
18 R
This week I noticed a very minor leak from the EXACT same bolt, but my immediate thought was to try and tighten the bolt and indeed it was noticibly loose.
I sprayed brake cleaner in that area and wiped it clean, tightened the bolt with a 10mm flare nut wrench and drove about 80km on the highway @ ~3k RPM.
So far no more seeping/leaking, so incase you guys experience the same thing, rather than changing the gasket right way, see if the bolt it loose and try to tighten it first.
autovelocity
Canada
18 R
aegis
Ontario
MK7 GTI
A ratchet box end is too fat (I tried one) and this one is a far better fit https://shop.snapon.com/product/Standard-Handle,-15°-Offset,-mm/10–11-mm-12-Point-Metric--Flank-Drive-High-Performance-15°-Offset-Box-Wrench/XDHM1011
Update: The bottom left bolt area started leaking again a few weeks after my last post so now I'm finally going to replace the entire plastic housing this weekend.
How did it go?
Mine has some weeping at the bottom backside, had some weeping around the back cam magnet as well.
I replaced the cam magnets, seals, and VVT valves this weekend. Thinking about replacing the whole cover. If it's not easy, was just going to take it to the shop.
autovelocity
Canada
18 R
How did it go?
After changing the whole cover there is zero leaking. I suspect that plastic cover warps over time due to heat and that is what causes the leaking because the seal was 100% fine. (not hard/brittle)
BudgetPhoenix
Kansas
2016 GTI S DSG
The ratcheting flex head box wrench posted does in fact fit both lower bolts on my car. Just gotta be careful not to get the wrench stuck backing it out lol if you run out of room. Best to use a long regular box end still probably. Guessing there will be slight variances between cars, especially if the motor mounts have ever been removed before
