Please. I won't even be mad. LOL I'm turning my 2015 GTI in to a dedicated track car. The car is still on stock suspension with a Neuspeed sway bar in the rear and Moog end links. Wheels are F1R F101 18x8.5 et38 with a 5mm spacer up front to clear the Stoptech ST40 brake kit. After the last track day, I took the Michelin 4S tires off and mounted a set of Hankook Ventus F200 slicks 240/640/r18. Now, let me just say I'm NOT surprised the tires are rubbing. But I need to rectify the problem before the next track day.
Options I'm considering are wider fenders or obviously suspension.That's where I need help. I know I'll need to change a lot of parts eventually given the way the car is being driven and to get the most out of it on track but I'm confuuuuused. I'm reading about camber and wheel offset, etc but I don't understand most of it. I'm also going to buy a dedicated set of track wheels but I don't know which ones clear the ST40 kit, with the exception of the Konig Countergram and even those require a 3mm spacer.
The rubbing is occuring on the outside edge of the fender. We removed the screw but haven't bent or removed anything else in the wheel well. Removing the screw did nothing but make it worse, likely due to remnants from the screw removal. The fenders haven't been rolled yet, fyi. As you can see from the pictures, there is quite a bit of poke. The tires are meatier than the Michelins, meatier than I imagined they would be. I didn't understand the middle number in 240/640r18, obviously. LOL
So for those who've done similar things to their GTI's, please enlighten me. I don't care about streetability. I just need to get rid of that rubbing! Would coilovers help? Alignment? Different wheels? Fenders? Which fenders? I'm currently in talks with SRS-TEC but I'm looking at a full four weeks before delivery. Is there a company in the US who sells them? Or a similar width fender? SRS-TEC's fenders are 2.5cm.
What would you do???
