Hi!
I've just installed some aftermarket LED DRLs on my Golf 1.2 TSi. Normally the control box (relay) of such lights is just connected to
- battery +
- ground
- low beam 12V (in order to dim the DRLs when you turn on the low beam). I'll use a t-tap connected to the low beam 12V cable on the headlight harness for this.
Unfortunately the control box that came with my lights doesn't seem to detect when the engine is started, which means the DRLs are always on, even if the car is completely turned off. This means I need to find 12V that's switched on with the ignition.
My car is a European version with halogen headlights if that matters.
To make a long story short: does anyone have any ideas on where to find switched 12V in the engine bay?
- battery +
- ground
