marauder
- Northern Va
It could just be a bad log with wheel spin. If you're other logs are reading more accurately. I posted some settings for vdyno a while back
The innovate gauge that's in another thread. Mounted in cubby like others. Ethanol Content Gauges/Kits is the thread where you'll find a link to the kit on amazon.what gauge/set up are you using to read E?
If you've been waiting for a COBB Accessport or part (including our tuning packages) the payoff is now! Nov15-21 is the kickoff to our holiday sales and it's one you don't want to miss on with 10% off all COBB tuning packages and parts on our site using the Cobb10 code.
How does this differ from the Cobb10 discount?
Edit: For anyone else wondering, this only applies to services not bundled with a Cobb AP.
I have a quick question. Slightly off topic, but I've finished my protune with Stratified, and I'm about to install a P3 OBD2 gauge. Is there anything about running a flash tune that will make the boost reading any less accurate than if I wasn't tuned? I'll probably run an actual boost line from under the hood later, but in the meantime...
No, just wondering why you not just keep the AP as your gauges?I have a quick question. Slightly off topic, but I've finished my protune with Stratified, and I'm about to install a P3 OBD2 gauge. Is there anything about running a flash tune that will make the boost reading any less accurate than if I wasn't tuned? I'll probably run an actual boost line from under the hood later, but in the meantime...
