Could be. I would think the clicking would happen right as soon as you would let off the gas though, this seems to take a second as the RPM drops. Do you have a boost gauge? If its a bad DV you would not be holding much boost. If any. You would probably notice quite a bit of power loss as well. You experiencing anything like that or just this noise? If its stuck shut you would probably hear some turbo flutter too higher up in the rev range. I actually know a few people who unplug their DV just for the flutter noise....It sounds very mechanical , as if something is closing. Could it be DV ?
Sound was from the stock DV. I unplugged the DV and the clicking sound went away ?
I did replaced it with a new DV but it still makes the same sound. Im guessing it is normal then.
