theDoktor
- Buffalo, NY area
- 2017 GTI Sport
I am investigating whether anyone has successfully staggered tire sizes for autocross with either the Mk6 or Mk7 GTI. Over the weekend I got to talk with and observe a local hot shoe running G Street quite successfully using narrower tires on the rear of his 2-dr. Mk.7 He's running the normal 245/40-17 RE71-R's on the front with 215/45-17's on the back. All are mounted on Enkei Fujun 7.5 x 17 rims. He's also running a Strano rear bar.
I got to watch all of his 8 runs, and I was impressed how flat his car was where my stock suspension had me up on 3 wheels to the point the Mini drivers were commenting... I'm running the same rims as his and 245/40-17's all around with completely stock suspension and spent the day trying to stay ahead of the back end of my car. By the end of the day my times were starting to get somewhat competitive, but no where near where I need to be. I know a rear bar is a high-priority item, but if I can't get the rear tires close to the temperatures the fronts are seeing, I'm going to be dealing with oversteer from the work imbalance, particularly with my driving style. Less rubber on the road in the rear doing the same amount of work might help with that.
I do have some concerns with the electronics if I change the rolling diameter of the tires between front & rear. TPMS might not like different diameters. I turn off stability control when on track, so that isn't a concern. Don't know about ABS though. Anything else I might have to deal with? I'm not talking about huge differences in diameter either- the 245/40's have a 24.7" diameter with an 8.6" tread width; the 215/45 also has a 24.7" diameter and a 7.2" tread width; the 205/45 has a 24.3" diameter and a 7" tread width.
Anybody out there with first hand experience with this? What have you observed at the Solo National level, Pro Solo or Tour and not necessarily just the GTI?
