After swapping wheels I’ve been playing with spacers to dial in the exact fit I want. In a perfect world I’d run 5mm up front and 10mm on the rear. The front is a non-issue. 5mm slip on spacers leave plenty of hub protrusion for the wheel to stay hub-centric. The issue is the rear…I ordered 10mm hub-centric spacers but the rear hub protrusion is longer than the spacer is deep. I threw one of the spacers on my Bridgeport and tried to machine it deep enough but as I figured I just cut off the part that the wheel would ride on…there’s not enough wall thickness for it to work. Long story short to run 10mm out back it will have to be a lug-centric fit. I don’t love that idea at all but I figured I’d see if anyone else had tried it and what the results were…especially at higher speeds?
