J Peterman
- USA
Sorry to hijack this but how do you like that combo of the bfi mounts with the powerflex dogbone insert? This is the setup I was going to do.BNIB, BFI Stage 1 dogbone insert with original hardware included. This is the Version 1 insert in Stage 1 lower durometer 70A poly.
Bought as part of the BFI S1 mount set, but chose to use a Powerflex insert instead. $35.
Thanks for looking.
No problem, I’m waiting to install the mounts/insert with an upgraded turbo but will post my impressions when that happens.
Posters on the forum seem to like all 3 BFI Stage 1 mounts together or the BFI mounts with a powerflex insert for reasonable NVH in a DD, or the BFI mounts with the Powerflex hybrid puck for a locked in experience with appreciable NVH (which can be mitigated with a RocEuro pendulum arm, bolts appropriately torqued).
The BFI Stage 1 V1 insert listed here is still available FS, will take offers.
Sometime around July of 2016 I believe.Do you know at which year they switched to v2? Floor jack is apparently broken and I can’t confirm
I drive a 2019 and have the V1, so it’s totally inconsistent. Whatever VW threw on from the Mk7 parts bin.
Easiest way to find out is to stick your arm underneath the vehicle and take a cell phone photo of the lower dogbone mount, no ramps/jack stands needed!
https://blackforestindustries.com/c...e-arm-insert-dogbone-insert-stage-1-version-1
The image on the BFI website is useful to determine V1 vs V2.
My 2017 has V2 as well.You're correct. 2017 with a v2. Just used your method
I ended up getting the stage 1 BFI mounts and the powerflex hybrid and it barely added any vibration at all.Just had the BFI S1 engine/tranny mounts with the 70A PF DB insert installed on my 6MT 4Motion GSW. Only change I noticed is an incredibly slight “fish nibble” at idle. NO shaking rear/side view mirrors, no vibration in reverse, nothing at all my wife will notice. Cabin noise is increased, which I like actually. Huge improvement.
