Sold: 2017 MK7 GTI SE 6MT Pure White
jeffecan
Lebanon, PA
2017 MK7 GTI SE
Hey all,
I’m Jeff, and I have been using this forum for quite some time. The amount of information, viewpoints, and helpful hints found from here is astounding, and has led me to where I am today with my car. It is, however, time to move on from this vehicle. There have been enough signs in my life recently that are telling me it’s time to let this car go, and to move onto new things. I recently bought my first house, and now realize all the projects that go along with that, and my wife and I have been wanting to start a family. I really want it to go to someone who can appreciate it, rather than just trade it in.
Bought new in May of 2017
2017 VW GTI SE Performance Package w/ Fender Audio
6-Speed Manual
Asking: $18,500
Mileage: ~87,000
Currently Tuned I.E. Stage 2 93 Oct.
Link to all photos here:
All Photos
Current mods:
OE Turbo IS20
H&R Rear 27mm adjustable sway bar
EMD Adjustable End-links
APR Catted Downpipe
AWE Track Exhaust w/ black tips
Turbosmart BOV Kompact Plumb Back
I.E. Turbo Inlet Elbow
034 Dogbone Mount/Insert
Spulen Turbo Outlet Pipe Kit
034 Subframe Collar Alignment Kit
034 Bearing Mounts for Struts
Koni Adjustable Yellow Struts
VWR Lowering Springs
034 Density Line Rear Adjustable Control Arms
034 Density Line Rear Adjustable Toe Arms
Fluidamper Engine Damper w/crank bolt
Southbend Stage 2 Daily Clutch/Flywheel
Motul Gear 300 75W90 Trans Fluid
VW Haldex Fluid w/new Plugs
Shifter Cable Bushings
DFG Tuning Short Shifter
Turbosmart Mechanical Boost Gauge
APR Boost Tap/Vent Pod
I.E. V2 Cold Air Intake
I.E. Catch Can
I.E. FDS Intercooler V2
EQT Coil Grounding Kit (Pro Series)
Spacers and Stud Kit (ECS Tuning)
OEM Wheels
Continental Extremecontact DWS 06 PLUS XL 2 in April (rear), 2 in August(front).
EBC Yellow Brake Pads in front, EBC Red in back
StopTech Drilled Slotted Rotors Front/Rear
Maxton Design Hatch Spoiler Extension V2
RBF660 Brake Fluid
Motul 5W-40 Oil every 5-7000 miles
Ruthenium Spark Plugs (current) changed every 15-20,000 miles
RS3 CoilPacks
Water Pump/Thermostat housing replaced at 74,000 miles
BFI Trans and Engine Mounts (Stage 2)
BFI Shift Knob
VWR Billet Oil Cap
Euro Headlight Switch
Not yet Installed:
Dieselgeek SuperPin
I.E. Trueflex Sensor and Harness
AutoTech HPFP Upgrade Kit (with tool)
Neuspeed SS Brake Lines Front/Back (Coated Yellow to match the Koni’s)
**I had a Minor at fault Accident, drove over Tractor Trailer retread early morning**
This happened about a month ago…and these items were replaced through insurance.
I.E. Intercooler
Radiator
AC Condenser
Bumper Assembly
V-Belt
Belly Pan & Clips
PXL_20221101_213234094.jpgPXL_20221101_213244441.jpgPXL_20221101_213401098.jpgPXL_20221101_213408077.jpgPXL_20221101_213422305.jpgPXL_20221101_221452757.jpg
The car was tracked on two separate occasions, both at Watkins Glen, once in 2017, and this year. They were just one day sessions. Other than the track days, this car was mostly driven to work, and/or traveling highways.
I took care of the car and I have put a lot of time and thought into this car, and wish that someone who can appreciate it, can have it.
It currently has ~87,000 miles on it and will increase as I drive to work every day. Oil change just performed with Motul 5w40 and new filter. I also have some more of the RBF660 racing DOT 4 Brake Fluid I'd include in the sale, along with the parts I haven’t installed yet. Please let me know if you have questions about the car, I am more than happy to answer.
EpicTech
Houston
MK7 GTI 6sp w/PP
literally my car except yours is white. GLWS.
jeffecan
Lebanon, PA
2017 MK7 GTI SE
Thanks all for the feedback. I'm really bummed about letting it go, I for sure will miss the fun I had with this car.
