anotero
- Hither and thither
- Mk7 GTI
Are there any issues with running a Unitronic ECU tune along with the Cobb DSG tune for a GTI?
Shouldn’t be, just don’t load the Cobb ECU tune. The TCU is it’s own separate computer
"computer" -- the Accesport, correct?
No. ECU = one computer, box, module, whatever you wanna call it
TCU = another computer
They’re completely different so tuning one has no direct effect on the tune installed on the other
Hm, interesting. I came across this on the Cobb website:
FEATURES
Volkswagen Accessport with DSG Flashing GTI (Mk7) 2015-2018 USDM
Includes Stage 1, Stage 2, and Stage 3 ECU Maps
Includes OEM+, Sport, Aggressive, and Aggressive IS38 DSG Maps
Customizable Multi-Gauge Display
High-Resolution Data Logging
In-Vehicle Mount with On/Off Switch
Ok, I’m not sure what you’re getting at. I understand what features Cobb offers
Yes, Cobb AP comes equipped to tune both the ECU & TCU. But to answer your original question- Yes, you can load just the Cobb TCU tune and leave your Unitronic ECU tune
The Cobb AP connects via obd2 port, but which tunes you load or leave alone are selectable independently
I would contact Cobb directly before you buy one just to be sure. Also, you already have Unitronic and they offer a DSG tune (as does APR) that will work with your existing tune. Both cost less than the Cobb route; the $400 cost is on top of the $650 for the accessport. Unless you plan on getting a custom Cobb tune, you're paying for a lot of capability you're not going to use.
True. If you’re just looking for a TCU Tune and don’t plan on increasing power through purchasing more parts and/or getting a Protune, the Cobb seems like overkill. Now if you think you may want more power down the line, then it makes sense to buy the Cobb Accessport as your can get a Protune to optimize and maximize your power potential and have a selection of DSG tunes for your TCU as well.
This is unfortunately untrue...I definitely agree. However, the Unitronic DSG tune is still restrictive compared to the Cobb one. It does not remove automatic upshifts and downshifts (at least from what I gathered on their website). It also doesn't make the shifts in manual as quickly.
The Uni DSG tune removes auto upshifts (if you wish) in Manual mode.
The shifts in Manual are quick. On pair with other OTS TCU tunes. The shift points in D and S are good too (not too aggressive and just enough in S mode). The only thing it lacks is clamping pressure. The Uni TCU tune should be used with the Uni ECU tune. Both being mild tunes and not as aggressive as others.
If you mix and match you are just asking for problems. Both vendors will deflect blame on the other party, and they are both partially correct. There are many ways to go about calibrating both ECU and TCU. Stick with a proven combo that others have tested or stay within one vendor.
