RMS leak. OEM or try iAbed again.
Jmitchell4873
Fort Leonard Wood, MO
Mk8 GTI
Looking for opinions from those of you have swapped the RMS.
Not many in the Mk8 world to get feedback from, so figured I would ask here since the sample size will be much larger.
I had a reputable shop install the iAbed when I did a clutch upgrade. It has a small leak after 3000 miles. Should I just go back to a revised OEM RMS or take the chance that the iAbed might have just been bad luck?
Daks
Toronto
GTI PP
It's small, leave it be. It will cost a lot to change back to OEM. My IaBED is the same, and I went to a shop that was approved to install it. Thing is a piece of shit.
Jmitchell4873
Mk8 GTI
I won’t be paying for this repair since it was only installed two months ago. The shop even offered to give me a courtesy car for the day or two that they have it back in the shop.
If you were going to replace your leaking RMS, would you go with OEM or try something different like the 034?
MonkeyMD
My trusted shop refused to install anything but OEM. had to sell my IABED at a loss
Jmitchell4873
Mk8 GTI
OEM only. Lots of things on these cars marketed as “upgrades” are not.
OEM should have been left in there…..but that ship sailed.
I am now one of those old men that will tell the youngsters to keep the “while you’re in there” stuff to only what’s absolutely necessary.
Daks
Toronto
GTI PP
OEM. Never actually heard of one fail on a MK7.
Jmitchell4873
Mk8 GTI
OEM RMS is installed.
iAbed was leaking between the crank flange and the seal itself, and yes it was installed correctly with the tool. This was the first known failure out of 52 iAbed installs from the shop I had do the work.
Very unfortunate.......but now I will see what Issam from iAbed has to say. His first reply was to make sure I knew that he didn't produce the actual seal......just the billet plate. I still feel that it is their responsibility to make it right, even though I'll end up eating the labor costs.
