cbr600rr
- Ottawa, Canada
Reverse - back up - Out of reverse, down to 2nd, up to 1st - drive away. This should eliminate any possibility of accidentally going back into reverse.
Nah he's talking about the fact that the manual gearboxes have a problem that you think you are in reverse & your are not but in 1st...so you try again...& fail....I had it & having VAG cars all manual & mechanicing on numerous VAG cars over 23yrs the gear linkage on the MK7 has way too much slop...even an alignment can't cure....all metal parts does solve it...
ive ordered the cable end bushings from awesome GTI the relay lever cant be bought on its own you need to buy the cable the shoe and a washer as its a kit total cost £51.46
https://www.awesomegti.com/shop-by-...-designs-shifter-bushing-kit-6-speed-my10-14/
these are the ones i ordered
the relay lever is £31.86
the cable is £13.61
the shoe is £5.40
and a washer is £0.59
they wont split it
