I found that heating button that is by the shifter on aliexpress. It says its decorative and cannot be pressed. Passats never had a button there. The passat buttons where on the climate control module. I looked in etka and could only find the climate control buttonSorry is wrong picture ( did it on my mobile phone ) i have one with heating
What are we talking about here? There is this part number... 3G0927238P... that appears to be valid. Not sure it matters anyway if you have Mk8 wheel with the heated steering wheel button on it.I found that heating button that is by the shifter on aliexpress. It says its decorative and cannot be pressed. Passats never had a button there. The passat buttons where on the climate control module. I looked in etka and could only find the climate control button
I was assuming we were talking parts that fit on golfs.What are we talking about here? There is this part number... 3G0927238P... that appears to be valid. Not sure it matters anyway if you have Mk8 wheel with the heated steering wheel button on it.
I have not seen any of the touch climatronic panels with a heated steering wheel icon. I suppose they are only on cars that either have the console button or have the button on the MFSW. Plus you can always press MENU on the climate panel and turn it on from the touchscreen too I guess.
Does the code come back when cleared?After a month of enjoying my heated steering wheel I have lost the heating function.
796675 - Heated Steering Wheel
B1538 04 [008] - Internal System Fault
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 72
Mileage: 45542 km
Date: 2022.11.30
Time: 20:50:34
Terminal 15 status: On
Terminal 50 status: OFF
CAN-Bus_aktiv: On
Status Bremslichtschalter (HW): OFF
Status Bremslichtschalter (CAN): OFF
OFF: operated
Position lamps: Not operated
Automatic high beam assist: Not operated
Low beam: Not operated
Parking light left: Not operated
Parking light right: Not operated
last_wakeup: no cause for fault protection
Voltage: 14.3 V
Outside temperature: 12.5 °C
I noticed it after completing the AID retrofit though I don't believe it to be the cause.
I have compared all the admaps prior to the install to the ones currently running and nothing has changed that references the Heated Steering wheel.
I have tested the power going to the clockspring for the heating function.....available.
When monitoring the measuring blocks, the signal to activate is registered but obviously the temperature sensor does not show any changes.
All other functions relating to the clockspring work fine.
I am stumped. Any ideas?
Thanks
Did you ohm out the element in the wheel.
Ya, if it's open circuit it's completely dead. As for a spec for resistance, it would depend on the type of wire used, it's length, and gauge. But a rough estimate would be around 2-3 ohms. Based on a guess it's 22 gauge nichrome wire.The code does return when cleared but not immediately......It reappears I imagine once I try to enable the heating function.
I did not ohm it out. I should though. What resistance would be considered normal? Something really low I would think. If the element has failed, should it show up as an open circuit?
I will disconnect the airbag and power up the system to scan for operating voltage post clock spring at the same time.
Thanks for the suggestions @xabhax
I got 2 Ohms so the element is not the issue.Ya, if it's open circuit it's completely dead. As for a spec for resistance, it would depend on the type of wire used, it's length, and gauge. But a rough estimate would be around 2-3 ohms. Based on a guess it's 22 gauge nichrome wire.
