Retrofit mk7.5 bsd
davide.bonetti
ITALY
pretty straight forward if you have a HIGH gateway.
remove rear bumper and install radars on both sides, run wiring inside.
it's only +12V, GND, EXT CAN and the two wires for the LED indicators.
if you want OEM job you need to replace the ext mirror glasses to get the LED indicators.
or you can use any 12V LED and install it anywhere (saves A LOT of work).
