When I got an EPC light in my car a couple months back, I would just restart it. It'd run fine, but I wouldn't go WOT.Hi,
I would like to ask if car suddenly go into limp mode while driving and cause engine stop. Is it any way to reset the limp mode so the car still can drive and not stuck in middle of some where ?
Thanks
Pretty rare for it to just randomly suddenly go into limp mode though. (iirc)
However, if it does try new coils / spark plugs.
With limp mode you should have an EPC light on the dashboard. When you restart the car it will reset but it is not fixed.
You can then drive again but if you try to use too much power it will trigger limp mode again. Do not start buying parts hoping to fix it. An EPC light can be tricky to diagnose. Often it will be wastegate related but still needs to be diagnosed. See link below for an explanation.
https://mechanicbase.com/engine/epc-light/
while running or when starting? I did read when running but want to check.
If running check battery connections. If at start-up check battery
If your engine won't start you need to find out why...Hi,
Thanks
Could be a bad alternator?If got into limp mode your engine still running ? for my case my engine is totally stop and cant start.
After left over night at workshop and did nothing the car back to normal can start without engine check light but not dare to drive it. Plan to bring back official service center to check again.If your engine won't start you need to find out why...
My battery newly change 2 month ago. Use the AGM standard batteryOn point. How old is the battery? If it's more than 3 years old, replace it.
I think so as during change battery i saw the mechanic got plug in the device.Was the adaptation done?
