All units will need coding to complete the install. Changing the coding directly to 00 will not result in setting back to factory default. In order to set the module back to factory default for North America, first code to 03, then back to 00.
List of Cent. Elect. Module #9 units with Xenon and Rear Fog
Build Date: May, 2010 - Chroptus (EU Golf TDI)
•Byte 18 coded to "43". All lights functional and at correct brightness.
Build Date: Jan 30, 2010 - ZIPN VW (NA GTI)
•Byte 18 coded to "15". All lights functional and at correct brightness.
•Byte 18 coded to "04". All lights functional, bumper marker and city lights are at low brightness. (no error with LED city light and bumper lights)
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 F HW: 1K0 937 087 F
Component: BCM PQ35 H 103 0575
Revision: 00103 AG
Coding: 69180A3E90272AC40008008170000D0445051586534D8D6064 8020200000
Shop #: WSC 93007 999 58668
Part No: 1K1 955 119 F
Component: Wischer 08011 21 0512
Coding: 009795
Build Date: Aug 14, 2009 - Dana (NA GTI)
•Byte 18 coded to "04". All lights functional and at correct brightness.
Part No SW: 1K0 937 087 G HW: 1K0 937 087 G
Component: BCM PQ35 H+ 103 0536
Revision: 00103 AC
Coding: 6D180A1E90272AC48088008550000D0441050486434D8D60648020200000
Shop #: WSC 01357 011 00200
Part No: 1K1 955 119 E
Component: Wischer 30060 21 0501
Coding: 009795
List of Cent. Elect. Module #9 units with Xenon and without Rear Fog
Build Date: May, 2010 - drunknfoo (NA GTI)
•Byte 18 coded to "55". All lights are functional and at correct brightness.
Revision: 00103 AG
Coding: 6D180A3E90272AC40088008160000D0441055586534D8D6064 8020200000
Component: Wischer 25041 21 0512
Coding: 009795
Build Date: Jan 20, 2010 - Orient Express (NA GTI)
•Byte 18 coded to "1F". All lights are functional and at correct brightness.
•Byte 18 coded to "43". One Reverse light works, the rest are functional and at correct brightness.
Component: BCM PQ35 H+ 103 0574
Revision: 00103 AF
Coding: 6F180A3E90252AC48008008174008D0445054386435D8D60648020200000
Coding: 009795
Build Date: Sept 26, 2009 - chadcronin (NA GTI)
•Byte 18 coded to "20". All lights are functional and at correct brightness (as far as I know).
Revision: 00103 AD
Coding: 65180A3E90252A048008008174008D0441052086534D8D60648020200000
Build Date: Aug, 2009 - finklejag (NA GTI)
•Byte 18 coded to "20". All lights are functional and at correct brightness.
List of Cent. Elect. Module #9 units with Halogen and with Rear Fog
petteri
•Byte 18 coded to "22". All lights functional and at correct brightness.
Build Date: Jan, 2010 - unick
List of Cent. Elect. Module #9 units with Halogen and without Rear Fog
Build Date: Nov, 2009 - sfpegasus (NA Golf TDI)
•Byte 18 coded to "1F". All lights functional and at correct brightness. (Hatch tails stay on when opened)
•Byte 18 coded to "21". All lights functional, bumper marker are at low brightness and city lights are at high brightness.
Component: BCM PQ35 H+ 103 0572
Revision: 00103 AE
Coding: 6D180A3E90272A04800800817000858441011F86534D8560648020200000
Component: Wischer 19100 21 0512
Coding: 009795
