So its getting to the point were our warranty is over with if we didn't purchase the extended warranty. Luckily for us we have the PZEV warranty that covered lots of parts as long as you are NOT tuned (Or they dont run a flash check on ECU).
MUST BE NOT TUNED, MUST NOT HAVE ANY MODIFICATIONS IN THE ENGINE BAY VISABLE (AIR INTAKE, DOWNPIPE, INLET PIPE, ECT) THEY WILL TRY AND VOID WARRANTY IF POSSIBLE.
3.23.2.3 15/150 PZEV/AT-PZEV CALIFORNIA EMISSIONS WARRANTIES TABLE
Some Volkswagen models may be specially equipped to meet California Partial Zero Emission
Vehicle (PZEV) or Advanced Technology Partial Zero Emissions Vehicles (AT-PZEV)
requirements, as identified on the Vehicle Emission Control Information Label located under the hood.
Additionally, PZEV/AT-PZEV models may be identified by checking the VIN for “Warranty Key” US9
(PZEV Coverage See Warranty Policy) in ElsaPro > Vehicle Data. The “Warranty Key” section
heading in ElsaPro only appears if a “Warranty Key” is attached to the VIN.
If a PZEV/AT-PZEV vehicle fails a Smog Check inspection, OR if any emission-related part is found to
be defective, the part will be repaired or replaced by Volkswagen for 15 years or 150,000 miles,
whichever occurs first, from the date the vehicle is delivered to either the original purchaser or the
original lessee; or if the vehicle is first placed in service as a "demonstrator" or "company" car, on the
date such vehicle is first placed in service. This represents the emission control system
PERFORMANCE WARRANTY and DEFECTS WARRANTY.
For these vehicles, Volkswagen of America, Inc., an operating unit of Volkswagen Group of America,
Inc. ("Volkswagen"), warrants to the original retail purchaser or original lessee and any subsequent
purchaser or lessee that every model year 2017 Volkswagen vehicle imported by Volkswagen and
certified for sale and registered in California:
Was designed, built and equipped so as to conform with all applicable requirements of the
California Air Resources Board (California ARB) and
Is free from defects in material and workmanship which cause the vehicle to fail to conform with
California ARB requirements, including any defect which would cause the vehicle’s onboard
malfunction indicator to illuminate, for 15 years/150,000 for PZEV/AT-PZEV models, whichever occurs first.
IMPORTANT: For High-Voltage batteries in Hybrid models equipped to meet AT-PZEV
requirements, the warranty term is 10 years or 150,000 miles, whichever occurs first.
150,000 miles, whichever occurs first, for PZEV/AT-PZEV vehicles.
WHEN THE WARRANTY PERIOD BEGINS
The warranty period begins on the date the vehicle is delivered to either the original retail purchaser or
the original lessee, or if the vehicle is first placed in service as a "demonstrator" or "company" car, on
the date such vehicle is first placed in service.
The following is a generic list of emission-related components which would be covered for 15 years or
Service Number* Component Covered For 15 Years/150000 Miles
1714 Oil Filler Cap
1726 PCV Valve
1911 Coolant Level Sensor
1913 Coolant Fan Con. Switch
1970 Direct Ozone Reduction (DOR) Radiator/Sensor
1978 Temperature Sending Unit
2005 Fuel Filler Cap
2007 Filler Neck
2010 Fuel Tank
2019 Gravity Valve
2022 Activated Charcoal Line
2024 Canister Purge Solenoid/Valve
2025 Canister
2038 Fuel Feed Line
2039 Fuel Return Line
2044 Fuel Line
2048 Leak Detection Pump1726 PCV Valve
2007 Filler Neck
2010 Fuel Tank
2019 Gravity Valve
2025 Canister
2038 Fuel Feed Line
2044 Fuel Line
2562 Volume Air Flow Sensor
2567 Vacuum Amplifier
2568 Idle Air Control Valve
2574 Throttle Position Switch/Sensor
2580 Intake Manifold
2588 Idle Air Control Valve System
2604 CO Content Pipe
2610 Exhaust Manifold
2617 Exhaust Pipe (Manifold to Catalyst)
2639 EGR Valve
2640 Secondary Air Injection Shut-Off Check Valve
2641 EGR Vacuum Hoses
2642 EGR Temperature Sensor
2644 Solenoid Valve
2654 Thermal Vacuum Valve
2655 Secondary Air Injection Relay
2665 Secondary Air Injection Pump
2666 Pressure Hose
2668 Anti-Backfire Valve
2670 Pre-catalytic Converter
2672 Three-Way Catalytic Converter Temperature Sensor
2673 Three-Way Catalytic Converter
2817 Ignition Coil Power Output Stage
2820 Ignition Coil (Tri-Coil Pack)
2823 Ignition System Control Module
2830 Distributor Assembly
2832 Distributor Cap
2834 Distributor Rotor
2839 Vehicle Speed Sensors (Camshaft Position Sensor)
2853 Spark Plug Wires
2855 Coil Wire
2870 Spark Plugs
2872 Knock Sensors
2873 Crankshaft Position Sensor
2884 Glow Plug
2885 Glow Plug Relay
3707 Park Neutral Switch
3730 Transmission Control Module
9009 Speed Sensor
9025 Instrument Cluster
N/A MIL Lamp2567 Vacuum Amplifier
2639 EGR Valve
2644 Solenoid Valve
2666 Pressure Hose
2855 Coil Wire
2870 Spark Plugs
2872 Knock Sensors
2884 Glow Plug
9009 Speed Sensor
MISCELLANEOUS COMPONENTS (EMISSIONS-RELATED)
Emissions-related hoses, clamps, belts, pulleys, tubes, fittings, sealing devices, and mounting
hardware are covered if they are used on one of the above components. For example, items such as
defective gaskets would be covered, i.e. Exhaust Manifold Gasket (2609).
The duration of the warranty on any miscellaneous component is equal to the duration of the warranty on the component it is used on.
