I have Goodyear Eagle Exhilarate on my stock GTI w/ PP now and I love them. TireRack used to have a review on them comparing them to the Michelin AS/3+, Continental DWS06, and Bridgestone RE980s but looks like the test has been taken down. Their review on YouTube is still up though:. In that review, the only metric that the AS/3+ beat it was dry grip, and only marginally. Wet grip was much better.
I have put 5k miles on them so far, and I can say they are very quiet. Driving on fresh smooth pavement you can barely hear them. Grip is absolutely phenomenal for all season tires, both dry and wet. There is an exit ramp where I like to test how well the VAQ works, and I can tell you that I can go as fast if not a bit faster as when I had Indy 500. They are on the expensive side though being so new I guess (came out last year)
Check out those tire rack links i posted, they are testing all the high performance all seasons.... for some reason one of the links is down..... The AS3s are known to be the firmest.... the DWS06 has a softer tire wall than both the AS3s and the PZeros AS+..... usually the complain is disconnected steering, however they still rate the PZero's as more comfortable and better overall... its issue is snow like mentioned earlier, the DWS does that best out of them all in the snow though, if you need that... I haven't tried the DSWs though, so i cant say....
Honestly if you search this forum "harsh ride" or "bump noises" etc, you will see these cars have a suspension that doesn't handle bumps the best... ... I dont know if i would swap perfectly good tires for that reason, you might not even be able to tell....
I have a copy of Consumer Reports New Car guide (May 2020) which features a section on tires. I am comparing it to the TireRack info. CR actually puts the PZero's at the same rating as the AS3+ for comfort (below average). The DWS06 are rated one step higher, at "average" the same rating the Cinturato P7's receive. The Cinturato P7's have the best possible rating for noise levels. In ultra high performance their best rated tire for both comfort and noise is the Quatrac Pros but TireRack classifies them as grand touring lol. For high performance all seasons they prefer the PureContact LS over the P7s. I know TireRack's testing is more thorough but it is still interesting. Would there be a huge drop off in handling and performance with Grand Touring tires? Sometimes I am confused by the TireRack results because I assume when they give tires ratings they only compare them to other tires in the same category. For example, the rating of the PZero's doesn't make any sense to look at vs the rating of the P7's or does it?
How much for what size?
So unless Pirelli is paying them or something... it seems to be the better tire, except for pure handling (AS3 better), and in the wet/snow (DWS better)
Too bad there is no direct testing of the Pirelli against the Goodyear, but from what i saw in that Tire rack test thats not available atm, the Goodyear didn't really beat the AS3+ like the Pirelli did, and the MPG was worse on the Goodyear vs the Michelin, as opposed to the other test where the Pirelli was by far the best, so that kinda of settled it for me...
The other thing I noticed is that at least in stock sizes, the AS3+ is heavier than the P7 Cinturato that came on my car. Its +3 lbs per corner I think? You can feel it. And you lose some fuel economy. But you do get loads of grip.
225/40 18 (stock GTI Austin wheel size)
PureContact LS 21lbs
P7 Cinturato 21lbs
PZero AS+ 23lbs
AS3+ 24lbs
GY Exhilarate 22lbs
DWS06 21lbs
Potenza 980AS 25lbs
PS4S 21lbs
Yeah, tire rack rack considers the Cinturato Grand Touring as well... how does CR test the tires? are they comparing them by actually testing them in the same car/day/track with a fleet of drivers and then noting down the quantitative and subjective data like the TR test reports I linked... thats how Tire Rack does the "tests"... they also have the customer ratings as well.... one is obviously much more helpful that the other.... i went to the CR website but all the tire reviews are all "locked" ... if its just like the TR "customer ratings", imo its not that helpful for comparing tires... its more a customer satisfaction metric, if they are getting what they expected... i would only really look at the "would you recommend a friend" rating in those....
