anotero
- Hither and thither
- Mk7 GTI
What are the benefits of a PCV block off plate? How does it compare to a CC? What are the drawbacks? Is it even worth it?
A “block off plate” is just the piece that replaces the PCV to allow a DIY CC installation. I don’t know of anyone selling them for Gen3 TSI outside of complete kits.
Bottom line is unless you’re tracking on 200TW or better tires and losing a bunch of oil from sustained Gs the money is better spent elsewhere.
So a block off plate has no bearing on carbon deposits from recirculating vapors?
Nothing you can do to prevent carbon on the intake ports on a DI engine, they’ll happen no matter what.
On a positive note, my car is 100% OEM in that department and still hasn’t needed cleaned in 96k miles
How do you know it hasn't needed to be cleaned?
Idk how much an OEM MPI retrofit is but that would prevent buildup
E85 won’t help since it’s DI. WM will help, but again cost the same as just cleaning it when the time comesE85 or Water Meth, as they spray in the charge pipe.
No rough idle, no mis fires.
Same as anything, you can throw time and money at whatever you want, but the car runs perfect and gets 30mpg with zero highway in my commute so outside of cool before and after pictures there’s not much to be gained from cleaning them early.
My plan has always been clean the valves when it runs rough or the water pump leaks, and neither has happened yet.
For those extra worried about it remove the MAP from the intake manifold and borescope it.
True, though don't the MPI kits offer port injection? Or is it just upgrading the stock Injectors?Would need to tune for it so total cost would be more than cleaning them and most don’t keep these cars long enough for one cleaning let alone two.
Would the runner flaps be in an appropriate position for me to get a glimpse at the valves? My idle is not rough really (considering I have BFI mounts and a dogbone insert, it could definitely be rougher), no misfires I can detect. Don't want to just go and have the valves cleaned if they don't need to.
I get up to 34mpg highway when running regular 91 and not E20. Gas mileage has not dropped significantly in the past 3+ years of ownership.
