To answer your question, there is one or two company's that make adaptors that come off the side of the filter housing and replace the factory oil/coolant exhanger, but it requires removal of the manifold and the water pump. Also they need to have a block off that runs to the exchanger to the water pump. You will also need an inline thermostat so your oil temps don't drop too low while you are at normal cruising speeds. My opinion would be to run a track day while it's hot and see what your temps are. If you don't see too much heat you probably won't need an oil cooler. Most people are not running oil coolers for track use but you will see dedicated track cars with oil coolers
