Hey, this is good news !!
Scroll down:
http://www.roadandtrackbyohlins.com/
http://www.ohlinsnews.com/current-i...nsion-developed-for-street-and-circuit-3.html
http://www.ohlinsnews.com/current-issue/project-under8-from-renault-3.html
Mk.VII PDF:
http://www.roadandtrackbyohlins.com/wp-content/uploads/2014/12/MI_VWSMP20_0.pdf
I would have prefered R&T dampers (which as some may remember have been available
for the Mk.V/VI for a short period of time) alone, to run them with DG springs, but I will
most likely get these R&T coilovers, cos I like it stiff, and my girl friend does as well. While
DCC is still great, full stock or with DG springs, I prefer Öhlins over it.
Some points which come to mind:
- the Mk.VII R&T seems quite similar to the Mk.V/VI version and will probably feel similar
- as mentioned, spring rates seem to be 70 N/mm front and 50 N/mm rear
- it'll also fit the Mk.VII R (4WD), GTD and lesser Golfs, as long as they come with multilink rear axle and 55 mm front strut
- while it's stiffer than most coilovers, spring rates are still less compared to Clubsport coilovers (KW, H&R, VWR)
- it'll probably ride better than most other coilover with similar spring rates due to its proprietary damping technology
- seems to come without adjustable camber plates
All in all, still DD-able and great suspension for the spirited driver. I'll most likely get a Mk.VII
GTI without DCC since the Öhlins is available. Track junkies will miss adjustable camber plates.
H2sport and others will probably supply suitable camber plates for those who need them. I hope
to achieve some added camber with TT control arms.
sources:
USA:
http://www.roadandtrackbyohlins.com/reseller/ohlins-usa-inc/
Canada:
http://www.roadandtrackbyohlins.com/reseller/chag-autosport/
Germany:
http://www.roadandtrackbyohlins.com/reseller/rent4ring/
