OEM-ish bump stops shorter than 55mm?
beanbag
Silicon Valley, CA
2018 Golf R
Hello folks,
Instead of cutting bump stops, are there any stock VW's that have ones shorter than 55mm, fat end approx 60+mm, for strut shaft 22mm? This would be for the front struts of a Mk7 R. (I know APR sells a 40mm one, of harder durometer) Would rather not cut bump stops due to [reasons].
00Zero
Pittsburgh, Pa
The Clubsport S and MK8 use 1K0 412 303 E and is quoted as softer than the standard to reduce understeer.
You could also have a troll around euro febi/bilstein website they list lengths but i couldnt find a VAG lenght shorter than 50mm
5x racing sells a 47mm that is 100 lb/in, I don't know how this compares to the factory rate.
APR is really probably the best bet and the harder durometer quoted doesn't necessary mean it is stiffer in rate just needs less material to achieve the same rate/progression.
