bobloblawGTI
- DC
- 19 GTI SE 6MT
Following this as it's the most bizarre thing.. fwiw the OBD port on my 2019 is also pink but no wings or tabs.
I can't see how that would be related. Unless you use navigation a lot I would just use Google maps.Yeah I'm thinking that's the best idea at this point. They did ask me if I wanted to pay $800 for a lifetime gps system so maybe that is related to it?
Sorry I meant to say the dealer gave me an option to have what they called an "advanced monitoring service" like LoJack but it was a different company. I didn't want that $800 option.I can't see how that would be related. Unless you use navigation a lot I would just use Google maps.
What about the ears?I suspect that the add that crap to every car on the lot and then try to sell it to you.
I'm not convinced that your OBD port is too large. Most ports are somewhat angled - I suspect it is the same size - just a different design.
My thought is that it's a dummy obd and it's connected to the real obd2 port which I attached a picture of. It's looks exactly like the dummyobd I sent ya'll a link of. We shall have to seeWhat about the ears?
If you look at the original design, you'll see how it slants on the sides - narrower at the bottom, wider on top.What about the ears?
I know they've always been wider and then narrow but his OBD dongle won't fit over the ears. His is the only one I've seen with those ears.If you look at the original design, you'll see how it slants on the sides - narrower at the bottom, wider on top.
Now, draw an imaginary line from the bottom straight up (instead of slanted and stop where the bottom of the ears are. remove the excess plastic and you have an OBD port with ears.
The one I have is not angled as much on the sides like everyone else.I know they've always been wider and then narrow but his OBD dongle won't fit over the ears. His is the only one I've seen with those ears.
You are correct. I didn't notice that before. I'm sure curious about it.The one I have is not angled as much on the sides like everyone else.
