ghalbart85
Throwing multiple codes here. So background information.
Initial setup was jb1 with CTS catted pipe with spacer from cts. Cel light stayed off then came on. Eventually due to the angle of the spacer the wiring frayed. My poor installation. The cel was on during this time letting me know about the bank 1 sensor 2. Also at this time the bank 1 sensor 1 code came on for the upstream sensor. No visual issues there. I checked the the signal wire with a voltmeter and said I was running at 45 mv which indicated a poor sensor.
Recently I replaced the downstream unit, removed the spacer, removed jb1, and flashed uni stage 2. Same codes, replaced the upstream sensor due to the possible faultiness from voltmeter test. No dice still running the same four codes.
Any thoughts?
Any thoughts?
