GTI Jake
- Charlotte, NC
NO IT DOES NOT!!!
The welded one is not spot welded. It is literally seam welded the entire way around the mount. There is no way in hell it can be taken apart with a drill. It does not have a two plate design like the riveted mount, so even if you get it apart, you'd have to fab up some way to hold it together. Stop spreading misinformation. I had the other revision mount, it is flat out impossible without a welder to reassemble the old mount.
If i sound frustrated, it's because of advice like this that i purchased the insert, only to find out that there was no way in hell i could make it work once i got it out. I've got angle grinder, a mig welder, and drill press, but still decided to ebay an older revision mount to throw the insert in as well.
Pics or it didn’t happen, because I had the vin code they said it wouldn’t fit.
Also? Why would it ever need re welded? The three piece mount on every car I’ve installed them on mk6 & mk7 the bolts that mount it to the chassis pass through both steel pieces (third piece being rubber). I’ve never re attached the halves split by drilling because they’re only riveted or welded to make it one piece to ship, not because that adds any structural benefits
I’ve also installed BFI complete mount. It’s just stuck back together with two tiny 3 or 4mm bolts (again, to keep it one piece for shipping no effect when it’s on the car)
