BigCanoe
- Moncure, NC
- 2017 GTI SE DSG
It looks like APR sells one tune that is good from 87-93 otherwise stock car? It must adjust.
That doesn't sound right.It looks like APR sells one tune that is good from 87-93 otherwise stock car? It must adjust.
That's a list of all the different maps available.Am I reading it wrong, I may be?
Negative. You can't flash it yourself. You pick a tune, go to a dealer and get it flashed. If you get a 93 tune, you keep putting 93 gas in there. You can maybe get away with 91 in a pinch if you dont floor it for the tank. I wouldn't making a habit of that. You could just get a 87 tune and put in 87, 89, 91, 93. It won't really adjust, but it will be safe to do.oooh...so I buy each one separately? Ouch. And then I can change them, like one tank 87 tune and the next 93 tune? Thank you!
Ah good to know! I thought APR used to have a way to use the cruise control to change tunes, but those days may be long gone. With Uni, I would need to buy the cable, but may be worth it.[/QUOTE
Yes, no more multi-tunes loaded on ECU. The Uni cable is $150.
People shouldn't be shy about just jumping to map 6 right off the bat. Even if you're not trying to get the most out of the tune, Map 6. Learn to use the JB4 and be happy.id go JB4, a map 2 1.8 tsi dynode 225 WHP on map 2 only mods were tune (intake, which does nothing ) on a 93 octane map, +5ish PSI , and hes jb4 and u can always adjust or go to map 1 which is 91 octane. Or just custom map 6 if u want to push more.
Right, the ECU will tell you what it likes or doesn't like. As long as you make reasonable changes, it's not dangerous. Yeah the log pulls. I assume people are being responsible and finding areas that are safe to do 3rd gear pulls. I think to get a real good picture, you'd need 2nd, 3rd and 4th. When you put it in that perspective, just a 3rd gear pull is easy and safe.i agree , once u understand ign1 , ign2-5 and IAT and how everything works you dont even need george, but some people shy away from the idea of doing a 3rd gear log going 160-170 KM/HR lol so they stick with presets
