Tuesday,22,September,2020,21:41:44:13895
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64)
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: WVWZZZAUZGW240047 License Plate: YD66NFL
Mileage: 56520km-35119mi Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZGW240047 Mileage: 56520km-35119miles
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Cannot be reached 0100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: Cannot be reached 0100
A9-Struct. Borne Sound -- Status: OK 0000
Address 01: Engine (J623-CUNA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 BS HW: 04L 907 309 R
Component: R4 2,0L EDC H22 1541
Revision: B5H22---
Coding: 011D0012036505083000
Shop #: WSC 00011 888 182020
ASAM Dataset: EV_ECM20TDI01104L906026BS 002003
ROD: EV_ECM20TDI01104L906026BS_002.rod
VCID: 7CF192CDF7DD20664F-8028
5 Faults Found:
19220 - Boost Pressure Regulation
P0234 00 [237] - Limit Exceeded (Overboost Condition)
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 3
Mileage: 56264 km
Date: 2020.09.21
Time: 06:21:32
Engine speed: 2117.00 /min
Normed load value: 29.8 %
Vehicle speed: 119 km/h
Coolant temperature: 91 °C
Intake air temperature: 113 °C
Ambient air pressure: 990 mbar
Voltage terminal 30: 13.300 V
Unlearning counter according OBD: 40
Charge air pressure specified value: 1485 hPa
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 952.4 hPa
Mass airflow sensor 1 bank 1 airflow: raw value: 371.9 mg/stroke
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.02 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 83.65 %
Turbine actuator 1 bank 1: posit.feedback - Act.value: 62.18 %
Mean injection quantity: 16.44 mg/stroke
25707 - Boost Pressure Regulation
P0234 00 [109] - Limit Exceeded (Overboost Condition)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Mileage: 56264 km
Date: 2020.09.21
Time: 06:21:32
Engine speed: 2117.50 /min
Normed load value: 29.4 %
Charge air pressure specified value: 1484 hPa
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 951.0 hPa
Mass airflow sensor 1 bank 1 airflow: raw value: 370.3 mg/stroke
10065 - Mass Air Flow Sensor (G70)
P0104 00 [104] - Intermittent
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 56165 km
Date: 2020.09.20
Time: 23:32:48
Engine speed: 111.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 70 °C
Intake air temperature: 55 °C
Voltage terminal 30: 9.540 V
Unlearning counter according OBD: 38
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Standardized airflow ratio: filtered: 3.9999
Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.32 %
Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 2.14 %
Charge air pressure specified value: 0 hPa
Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 999.0 hPa
Mean injection quantity: 0.00 mg/stroke
19257 - Oxygen (Lambda) Sensor Signal B1 S2
P2270 00 [236] - too Lean
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Mileage: 56208 km
Date: 2020.09.21
Time: 04:27:36
Engine speed: 2221.00 /min
Normed load value: 71.8 %
Vehicle speed: 125 km/h
Intake air temperature: 154 °C
Voltage terminal 30: 13.040 V
Mass airflow sensor 1 bank 1 airflow: raw value: 606.8 mg/stroke
Mean injection quantity: 31.46 mg/stroke
Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 134 hPa
O2 bank 1 dwnstrm. of oxi cat: elec. corrected pump current: 0.0028413 A
Oxygen sensor bank 1 after oxi cat: heater activation: 43.500 %
Oxygen sensor bank 1 after oxi cat: status signal quality: 1
Oxyg.sens.bank 1 after oxi cat: curr.pump curr.adaptat.: 0.7603
4709 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [047] - -
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:37
Engine speed: 0.00 /min
Coolant temperature: 52 °C
Intake air temperature: 46 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 11.880 V
Drivetrain coordinator: ACC fault status-Bits 0-7: 0
Drivetrain coordinator: brake fault status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 0
Drivetrain coordinator: brake function status-Bits 0-7: 4
Acceleration: 0.000 m/s²
Readiness: 1 3 0 0 0
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 041 J HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4904
Revision: 06253104 Serial number: TFK01601080008
Coding: 0014
Shop #: WSC 04742 780 00200
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1F4B8541068B9B7E0A-804A
No fault code found.
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 60076000002176
Coding: 01FA8AA13424096C0777060441CA2980512C90E0608294F518625078C209
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
ROD: EV_Brake1UDSContiMK100IPB_034.rod
VCID: 7AFD94D5FDE91E565D-802E
2 Faults Found:
8192 - Databus
U1121 00 [009] - Missing Message
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 109
Date: 2020.09.20
Time: 04:47:40
8196 - Databus
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 109
Date: 2020.09.20
Time: 04:47:40
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 5Q0 959 435 A HW: 5Q0 959 435
Component: VWKESSYMQB 021 0604
Revision: 00021000 Serial number: 0393817819
Coding: 100D0C
ASAM Dataset: EV_KessyHellaMQBAB 002011
ROD: EV_KessyHellaMQBAB_002.rod
VCID: 3A7D54D5BD69DE561D-806E
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00120104202100011005000000101002
ASAM Dataset: EV_ACClimaBHBVW37X 004131
ROD: EV_ACClimaBHBVW37X_004_VW37.rod
VCID: 6ADDA4958D49AED6AD-803E
Fresh Air Blower Front:
Geber für Kältemitteldruck/Kältemitteltemperatur:
Air quality sensor:
2 Faults Found:
262914 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:38
Outside air temperature: 18.0 °C
Engine speed: 0 /min
Compressor current: actual value: 0.020 A
Temperature after evaporator: 26.3 °C
System run time-Engine running time: 0 s
System run time-Terminal 15 on: 255 s
590082 - Control Circuit for A/C Compressor
B10A9 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:42
Compressor shut-off requirement: Low pressure event
Compressor current: specified value: 0.000 A
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061602703678
Coding: 03011B46C24122FB0BA44080311C03281800000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 091FFB19A80F05CE44-805C
Control Unit For Wiper Motor:
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 151211 042 0551
Serial number: 160120003120
Coding: 0E4DDD
Rain Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S5Y16M02D04H13M20S30
Coding: 90A8DD
Sensor For Anti Theft Alarm System:
Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150073XA4
Alarm horn:
Subsystem 4 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0313
Serial number: 00000000000064740801
3 Faults Found:
534549 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 106
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:38
540693 - Databus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 106
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:38
787462 - Relay for Headlight Washer System
B1262 15 [009] - Open or Short to Plus
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 106
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:37
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39391602302392
Coding: 0071051011
ASAM Dataset: EV_EPHVA18AU3700000 002026
ROD: EV_EPHVA18AU3700000_002_VW37.rod
VCID: 43832931CAA39F9E4E-8016
Address 13: Auto Dist. Reg
Cannot be reached
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 015 0388
Serial number: 003MLR1EU6FA
Coding: 98CCC000000000005C0000CF00C800000065
ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
ROD: EV_AirbaVW20SMEVW37X_VW37.rod
VCID: 7F0B65C1E6CB3B7E6A-802A
Belt Pretensioner left:
Belt Pretensioner right:
Side Sensor Driver Front:
Subsystem 3 - Part No SW: ----------- HW: 480 000 202 16
Component: SideSensor_Df 001 0887
Serial number: 357670000002FC1CE817
Coding: 2D2D2D
Side Sensor Passenger Front:
Subsystem 4 - Part No SW: ----------- HW: 480 003 009 16
Component: SideSensor_Pf 001 0887
Serial number: 35867000000AF1781F11
Coding: 2D2D2D
Side Sensor Driver Rear:
Subsystem 5 - Part No SW: ----------- HW: 480 402 701 16
Component: SideSensor_Dr 001 6149
Serial number: 3516502C91E9F104A13F
Coding: 2D2D2D
Side Sensor Passenger Rear:
Subsystem 6 - Part No SW: ----------- HW: 480 402 701 16
Component: SideSensor_Pr 001 6149
Serial number: 3526502C91E9F102D1CQ
Coding: 2D2D2D
Front Sensor Driver:
Subsystem 7 - Part No SW: ----------- HW: 480 400 907 15
Component: FrontSensor_D 001 6149
Serial number: 3556502BD1B7E8F4111R
Coding: 2D2D2D
2 Faults Found:
9634899 - Control Module for Front Left Belt Tensioner
B1304 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:37
9635155 - Control Module for Front Right Belt Tensioner
B1305 53 [009] - Deactivated
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:37
Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0120
Revision: -------- Serial number: 28011604220498
Coding: 0410
ASAM Dataset: EV_SMLSKLOMQB 020001
ROD: EV_SMLSKLOMQB_020_VW37.rod
VCID: 071BFD21BE1B73BE52-8052
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 5G1 920 957 A HW: 5G1 920 957 A
Component: KOMBI 302 6420
Coding: 23AD11182380260001086A000400000000000000
Shop #: WSC 12345 001 136936
ASAM Dataset: EV_DashBoardVDDMQBAB 009046
ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
VCID: 2E556885712102F6B1-807A
1 Fault Found:
10485833 - Internal Control Module Memory Check Sum Error
B2000 49 [009] - Internal electronic failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 38658 km
Date: 2018.10.13
Time: 00:00:07
Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial number: 0004453765
Coding: 030100041F087300FB00027E1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_013.rod
VCID: 79FF8BD9F8EF154E54-802C
Alternator:
Multi Function Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160000152710036037
Coding: 2DFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 1944499003
4 Faults Found:
131668 - Headlight Range Control Module
U101E 00 [009] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:38
Supply voltage: Terminal 30: 11.7 V
Terminal 15: On
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 106
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:38
Terminal 15: On
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 149
Mileage: 56131 km
Date: 2020.09.20
Time: 03:39:37
Supply voltage: Terminal 30: 12.4 V
Terminal 15: OFF
65798 - Extended CAN in One-Wire Mode
U0054 00 [009] - -
Freeze Frame:
Fault Priority: 2
Fault Frequency: 98
Reset counter: 114
Mileage: 56141 km
Date: 2020.09.20
Time: 04:05:43
Supply voltage: Terminal 30: 14.3 V
Terminal 15: On
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 5Q0 905 861 A HW: 5Q0 905 861 A
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000011416006
Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111
ROD: EV_ELVMarquMQB.rod
VCID: 34617AED9F0D2826C7-8060
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 161215ELE08997
Coding: 003F1220D001048000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
Drivers Door Rear Control Module:
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 005 0005
Serial number: 00000000000008796757
Coding: 0D0000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8103
ASAM Dataset: EV_SteerAssisMQB 012140
ROD: EV_SteerAssisMQB_012_VW37.rod
VCID: 397F4BD9B86FD54E14-806C
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 140916EID35056
Coding: 003F1020DE01048000801000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 428D2C35D5B9969645-8016
Passengers Rear Door Control Module:
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 005 0005
Serial number: 00000000000011659905
Coding: 150000
1 Fault Found:
65799 - Door Warning / Entry Lighting
B1775 01 [009] - Electrical Failure
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 106
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:37
Address 55: Headlight Range
Cannot be reached
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 A HW: 3Q0 035 874 A
Component: MU-S-ND-ER 820 0624
Serial number:
Coding: 02730001FF00000051111101008808001F0202C601200100CF
ASAM Dataset: EV_MUStd4CDELP 001001
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 306976FD6B151406A3-8064
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H41 8077
Serial number: VWZ6ZDT0631249
Data medium:
Subsystem 2 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
Serial number: --------------------
4 Faults Found:
1555 - Check Software Version Management
B201A 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 8
Reset counter: 114
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:38
Voltage terminal 30: 11.8 V
Status_Software_Version_Management-module_name: C
6691 - Local Data Bus
U10BA 00 [008] - No Communication
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 151
Mileage: 56118 km
Date: 2020.09.20
Time: 02:27:26
Voltage terminal 30: 12.8 V
Network diagnosis-Status: not enabled
7173 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 106
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:41
BAP-BAP_Function_ID: 02
7195 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 106
Mileage: 56076 km
Date: 2020.09.18
Time: 11:39:41
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 151113201417
ASAM Dataset: EV_SoundActuaGen2AU64X 003010
ROD: EV_SoundActuaGen2AU64X.rod
VCID: 6BD3A19182B3B7DED6-803E
End-------------------------(Elapsed Time: 04:40)--------------------------
