I read it during brakefast.No it's not. I read it while on brake at work.
So I plan on keeping the car at the very least for the next 5-7 years / untill I pay It off. I want to keep it forever but I do also eventually want an rs3 lol. And what about hardware? Do those kits come with all required hardware?That's for the PP brakes, so not what you'd want.
I don't think there's a pre-assembled kit with the blanks for the non-PP brakes. Here's the blanks:
Front Rotors: https://www.fcpeuro.com/products/audi-vw-brake-disc-ate-1k0615301aa ($62/ea)
Rear Rotors: https://www.fcpeuro.com/products/audi-vw-brake-disc-ate-1k0615601aa ($34/ea)
If you do want to give your car a little pizzaz (well worth it IMO), here's the slotted sport rotors:
Fronts: https://www.fcpeuro.com/products/audi-vw-brake-disc-zimmerman-sport-1k0615301aa ($91/ea)
Rears: https://www.fcpeuro.com/products/audi-vw-brake-disc-zimmermann-600324152 ($82/ea)
So it is an extra $150 or so for the cool factor.
I don't like FCP's pad options. I like ceramic pads for the low dust\noise properties, and their selection isn't that wide. The PowerStop pads are $38 a set for front and rear, so hard to beat for under $80.
Front Pads: https://www.rockauto.com/en/moreinfo.php?pk=7132920
Rear Pads: https://www.rockauto.com/en/moreinfo.php?pk=7132952
I get the lifetime warranty thing from FCP, but you could buy almost 3 sets of those for the price of a ceramic pad from FCP. Do you plan on keeping\using the car enough to swap pads 3x times to make the warranty worth it?
What would you prefer the title be?Thread title so misleading
And is there really any noticeable performance difference in a car not going to be tracked between the super affordable rotors you. Shared and the drilled rotors you shared? Other than cool factor, do the drilled have any major benefits over the non drilled?That's for the PP brakes, so not what you'd want.
That was a joke, bro.What would you prefer the title be?
This.More stopping power is usually down to better tires. If you can activate ABS when slamming on the brakes, your brakes have the capability to lock up your tires - so grip is your problem.
Lol I know, just felt like being sassyThat was a joke, bro.
So in total, your recommended brake job will total out to be roughly $335.70 which is far better than the $600-1100 I expected to spend.They come with all the necessary hardware, but not the "necessary" hardware. You can buy just pads and rotors and do the brake job, but like I said, there are some bolts that are technically one time use and should be replaced.
Front bolts: https://www.fcpeuro.com/products/vw...t-mounting-bolt-front-passat-cc-vag-n91084901 x4
Rear bolts: https://www.fcpeuro.com/products/audi-vw-brake-caliper-bolt-febi-n91168901 x4
Rotor set screw (not single time use, but cheap enough): https://www.fcpeuro.com/products/vw-brake-rotor-set-screw-n10648301 x4
The only other thing you'd need which would be highly recommended, is some fluid to flush the brakes.
He's making a joke about the misspelling of "brakes".
No.
So true. And I'm lucky enough to have him close to me to be able to help actually complete the work he talks about. I will be taking him up on the offers to help.Ask and Acadia18 will show you the way.
Here is my complete part list (thanks to your help):
View attachment 295435View attachment 295436
(x4) https://www.fcpeuro.com/products/vw...t-mounting-bolt-front-passat-cc-vag-n91084901
(x4) https://www.fcpeuro.com/products/audi-vw-brake-caliper-bolt-febi-n91168901
(x4) https://www.fcpeuro.com/products/vw-brake-rotor-set-screw-n10648301
(x1) https://www.fcpeuro.com/products/super-dot-4-brake-fluide-1-2-liter-1204114-1204115
(x2) https://www.fcpeuro.com/products/audi-vw-brake-disc-ate-1k0615601aa
(x2) https://www.fcpeuro.com/products/audi-vw-brake-disc-ate-1k0615301aa
(x1) https://www.rockauto.com/en/moreinfo.php?pk=7132920
(x1) https://www.rockauto.com/en/moreinfo.php?pk=7132952
Perfect. Will do.Looks good. Only thing I'd change is just grab 2x of the 1L bottles of fluid. For $3, better to have more than enough.
