New 18" Enkei TMS and TFR Flow Forming Wheels
Bassman
Greenville, SC
2017 GTI SE DSG
What do you think about these Enkei rims,
will they work with my reflex silver metallic GTI ?
I'm on the fence between the TMS and TFR style.
Strom Gray or Gloss Back?
Please help me decide !
Enkei TMS
Size 18x8.5
Bolt Pattern 5x112
Offset +45mm
Bore 72.6mm
Weight ~21 lbs (Tire Rack)
Price $232.50
Part No. 515-885-4445GR -> Enkei TMS Storm Gray
Part No. 515-885-4445BK -> Enkei TMS Gloss Black
Enkei TFR
Size 18x8
Bolt Pattern 5x112
Offset +45mm
Bore 72.6mm
Weight ~19 lbs (Tire Rack)
Price $225
Part No. 516-880-4445GR -> Enkei TFR Storm Gray
Part No. 516-880-4445ZP -> Enkei TFR Copper
demi9od
NC
Yeah I posted the TFR in the lightweight wheels thread. Light, stylish, and easy to clean.
Bassman
Greenville, SC
2017 GTI SE DSG
Easy to clean is always good :)
What do you guys think about the stance with the TFR ?
10mm spacers at the back ?
demi9od
NC
Yeah 10mm back and 5mm front optionally. Personally I'd go for 8.5" wide wheels though et45 and no spacers.
CDM MK7
Canada
I'd do the TMS in gloss black for a silver car. Spacers as needed, slight drop to kill the wheel well gap. I'm sure the TFR will be easier to clean, but gloss black almost negates that advantage.
nype
Vancouver, B.C.
It’s a lot of grey on grey. Do the TFRs come in black?
Either 5mm/10mm spacers...or maybe no spacers front and some camber adjustment rear to push top of tire out 5mm. Car will stay cleaner. [emoji1303]
Bassman
Greenville, SC
2017 GTI SE DSG
Any suggestions in 18x8.5 et45 ?
- Konig Ampliform
- Enkei TMS
Could I run the stock tires 225/40 on a 8.5“ wide rim until they are done and then change to 235/40 ?
nype
Vancouver, B.C.
- Konig Ampliform
- Enkei TMS
Ampliforms in the the darker grey. And yes to tires question.
Bassman
Greenville, SC
2017 GTI SE DSG
Actually I do not like to clean rims, so I think to go with the TMS in gloss black :D
I had gloss black rims on my previous car and I had no regrets with them!
jeffkro
United States
I think enkei pdc's would look cool but they are heavy and not flow formed. Seems I always like they heavy poorly made rims the best.
Bassman
Greenville, SC
2017 GTI SE DSG
I'm not sure with which ones I will go...
But I have a general question about wheel offset (et).
On the picture above I'm currently running a flush kit (15/20mm) on my GTI.
OEM rims have 49mm offset. With the spacers they will convert my offset to 34mm front and 29mm rear. Is that correct ?
For example, if I would go with the Enkei TFR in 18x8" et45 compared to my existing setup:
Front 18x7.5" et34 -> 18x8" et45
Compared to your existing wheel, this new wheel will have an inner rim which is 17.4mm closer to the suspension strut. The outer rim will poke out 4.7mm less than before.
Rear 18x7.5" et29 -> 18x8" et45
Compared to your existing wheel, this new wheel will have an inner rim which is 22.4mm closer to the suspension strut. The outer rim will poke out 9.7mm less than before.
With the new set of rims I probably have to give my GTI a slight drop to reduce the wheel gab and I'm pretty sure I could live with the not so flush stance.
Savannah Golf R
Nashville TN
My GTI setup since March 2018, They look amazing, however the weather is not great for photos.
Gloss Black
Enkei TMS
Size 18x8.5
Bolt Pattern 5x112
Offset +45mm
