Need new ecu..... help?
CoryJo
Hanford. CA
mk7 gti autobahn pp
Amp.plaus is the ambient air pressure sensor plausibility issue, which is located inside the ECU.
Not sure what you were changing around but this is sometimes seen iirc with incorrect MAP and PUT scaling.
car had a new 5bar MAP and 4bar PUT, it was coming up the amp.plaus. untuned. maybe that was the cause. i was just being overly worried i guess.
how ever. 3 more codes to deal with. car was running fine, took it for a spin, just to make sure everything felt alright, there is some weird knocking in the right rear, kinda sounds like the charcoal canister is loose, anyways. moved the car into the garage. it sputtered and died. and threw these codes. so im going to pick up some more gas and fill it up. see whats going on. < nothing was changed fuel related. it just randomly thew these codes today
CoryJo
Hanford. CA
mk7 gti autobahn pp
p025c code still persists, fuel pump wont prime with door being open, or on ignition. verified ground, connectors, car starts. and runs for a second. and then seems to die, as if out of gas.
added 2.5 gallons. gauge shows plenty of gas. car did run/idle/fine earlier. . evap code is gone. and p025a code also gone.
