keggo
- California
- TDI S 6spd
Just tried setting Leuchte27 to 38 - Blinkleuchten but no change. Except for making the turn signal relay run rapidly haha
So Leuchte27 is a single channel. You will not be able to make the left and right operate individually. What you do is basically repin your left reverse light (the drivers inner side) from pin 4 to pin 3 so basically all three wires are beside each other.Okay, so:
1. I installed the lights including running the yellow wire on both sides.
2. Reset coding back to stock from the previous mod so all the stock halogens brightened for braking.
3. Noticed the indicators were on, solid, during running lamp mode. Figured out the Leuchte27 thing and turn it to not active.
4. Couldn’t figure out the coding so I took to the internet and found this post linked from another post. Haha
All my lights, inner and outer, were set to 14 - kombiniert, but according to #5 on @ZERO815’s sheet, I changed 23SL and 24SL to 43 - Allgemeine LED. The tail lights looks great otherwise. The running lights and brake lights look fantastic. I have also tested modes on Leuchte27 to make sure the indicators work, and they do, just not as individual indicators.
I’ll head out there right now and see what I can try. I haven’t tried setting Leuchte27 to Blinkleuchten.
Then just code the left reverse to be your left turn signal. It works because in this case, your driver side inner will power the driver side outer turn signal via the yellow wire included separately that you will wire through the hatch.
I've talked to Zero and he doesn't know either.Yeah, I know it’s a single channel, just curious how Cssoz got it all to work without repinning. I want to keep the install as non-destructive as possible.
Apparently repinning isnt really destructive - you just undo a little clip and push out the pin with a SIM card tool.
Leuchte20BR LA71-Lichtfunktion B 20 | Blinken links Hellphase | not active |
Leuchte20BR LA71-Lichtfunktion C 20 | Blinken links Dunkelphase | not active |
Leuchte21BR RC8-Lichtfunktion B 21 | Blinken rechts Hellphase | not active |
Leuchte21BR RC8-Lichtfunktion C 21 | Blinken rechts Dunkelphase | not active |
Guys try
Leuchte20BR LA71-Lichtfunktion B 20 Blinken links Hellphase not active
Leuchte20BR LA71-Lichtfunktion C 20 Blinken links Dunkelphase not active
Leuchte21BR RC8-Lichtfunktion B 21 Blinken rechts Hellphase not active
Leuchte21BR RC8-Lichtfunktion C 21 Blinken rechts Dunkelphase not active
Assuming you haven't re-pin anything yet of course
I believe on top of the Single Channel Lasttyp27 to 36 LED, the above settings are what got mine working properly.
I just went through my OBD11 history one step at a time using a translator too LOL.
f*** i just realize my signal lights doesn't work as it should either.Haha I will try this, though I swear I did it. Lol
You’ve confirmed that both indicators work independently, yeah?
how did you unhook the tab on the connector and access the PINs ?I finally just repinned the connectors haha Thanks, everyone Should be pretty easy to fish the wire to join the two reverse lights now.
How are you going to bridge the reverse lights together ?Haha I will try this, though I swear I did it. Lol
I swear it did RIGHT after i coded everything. hence i was so happy. I just try it, right signle turns on the hazard lights.
You used SIM card tool to push the pins out ?
Got the reverse lights all buttoned up. Huzzah!
I got it all done pretty quickly. Did all the coding first, then repinned, then bridged the lights. Just make sure you properly insulate the outer left grey/black pin when you remove it.
You need to put two needles in the two small holes (one above and one below) of the hole in front of the connector.I can't seem to know the way to push the PIN out. i try pushing down in the middle, bottom or top as pictured below after opening up the tab.
Any tricks and tips ?
