StorableComa
- SoCal, USA
- 17 GSW S FWD
11 BAR is waaaay to high anyhow. Aftermarket MPI injectors are generally rated only up to 5-7 BAR pressure
Totally confused here as I am about to do MPI on my car and shop tells me my mpi harness pins into OEM ECU harness? What the hell am I missing here? Check your pinout locations and go from
I might do that, totally down to share knowledge.I'm confused too... I've gone over the pin out numerous times. I've talked with others smarter than me. if you're about to, you should be good. If you're worried about it, I'm an expert on it now, come up to central texas lol.
Brian
