MK7_305's GTI
mk7_305
FL, USA
I figured it’s about time to start a build (built?) thread. I’ve spent a lot of time (and a few dollars) getting this car dialed-in just the way I wanted. There’s still some work left to be done, but she puts a smile on my face.
Engine / Powertrain
- APR Adjustable Short Shifter
- APR Boost Hoses
- APR Catback Exhaust System
- APR Intercooler
- APR Shifter Cable Bracket
- APR Silicone Coolant Hose
- APR Stage 3+ Fueling System
- APR Throttle Body Charge Pipe
- BFI Stage 2 Engine & Transmission Mounts
- Braille G30 Lithium-ION Battery
- Cobb AccessPort w/ Custom 93 Octane Tune
- CTS Turbo Intake
- CTS Turbo Shifter Endlink Bushings
- ECS Tuning Clutch Bleeder Block
- ECS Tuning Performance Inlet Scoop Kit
- EQT Coil Grounding Kit
- EQT Vortex XL Turbocharger
- EQT 2.5” Discharge Pipe w/ Turbo Muffler Delete
- Fluidampr Crank Pulley w/ ARP Crank Pulley Bolt
- iABED Billet Aluminum Rear Main Seal
- Motul Gear 300 Transmission Fluid
- Motul 300V 10w40 Engine Oil
- MST High Flow 3” Turbo Inlet
- NGK R7438-9 Spark Plugs
- PowerflexUSA Lower Engine Mount Hybrid Bushing
- Sachs Performance 4 Puck Clutch w/ DMFW
- Spulen Billet Spherical Catch Can Kit V2
- Swoops Built Custom Battery Box
- Trackslag Catless Downpipe
- USP Cool Flow Aluminum Oil Filter Housing
- Wavetrac Limited Slip Differential
Brakes / Suspension / Wheels
- Audi RS3 Brake Deflectors
- EuroCode Adjustable Sway Bars (F&R)
- EuroCode Adjustable Sway Bar End Links (F&R)
- EuroCode Chassis Braces (F&R)
- Ferodo Racing DS2500 Brake Pads (F&R)
- GiroDisc Slotted 2-Piece Rear Brake Rotors
- iSWEEP Front Center Floor Brace
- iSWEEP Rear Center Floor Brace
- iSWEEP Rear Member Brace
- KW V3 Adjustable Coilovers
- Michelin Pilot Sport 4S Tires (255/35ZR-18)
- Motul RBF 660 Brake Fluid
- StopTech ST40 Slotted 355x32 Front Big Brake Kit
- SuperPro Alloy Control Arms
- Titan 7 T-S5 Forged Wheels (18x8.5 ET44)
- Tyrolsport Deadset Rigid Subframe Kit (F&R)
- USP Stainless Steel Brake Lines (R)
- USP Titanium Wheel Bolts
- Vorshlag Camber / Caster Plates
- VW GTI Performance Package Rear Brake Calipers
- 034Motorsport Rear Adjustable Toe Links
- 034Motorsport Rear Adjustable Upper Control Arms
- 034Motorsport Rear Shock Mounts
- 034Motorsport Spherical Rear Trailing Arms
Cosmetic / Interior / Misc / OBD11 Tweaks
- AeroForce Technology Vent Pod
- Anker PowerCore Jump Starter mini
- Audi Screenwash Tank Cap
- BEC HID Headlights w/ Morimoto 5500K HID Kit
- BMS Short Throw Clutch Stop
- CF Display Background
- Clutch Return Spring Removed
- deAutoKey LED Lights (Entire Interior)
- Debadged Rear and Sides
- Ecliptech Shift-P2 RPM Gauge
- ECS Tuning Jack Pad Kit
- ECS Tuning Jack Pad Cover Kit
- Engine Cover Removed
- ESC Off
- Helix Spare Tire Mount Subwoofer
- Hood Insulator Removed
- Hood Rear Seal Removed
- Leyo Motorsport Billet Aluminum Knobs
- MoJoMats
- MuddyBuddy Trunk Liner
- P3 Boost Gauge
- Rennline Aluminum Pedal Set
- Rennline Fire Extinguisher Mount w/ Quick Disconnect
- Rennline H3R 2.5LB Fire Extinguisher
- Slime 70005 Flat Tire Repair System
- Soundaktor Off
- Spare Tire Removed (Only used on road trips >100 miles)
- Stack Pro-Control EGT Gauge
- Starting Vibration Reduction Off
- Valentine One Radar Detector
- VW Alltrack Skid Plate
- VW Auto Dimming Homelink Rear View Mirror
- VW Emergency Road Side Warning Triangle
- VW Euro Aspherical Side Mirrors
- VW Euro Folding Side Mirrors
- VW Euro Cherry Red LED Tail Lights w/ BEC Harness
- VW Euro Golf R Performance Pack Rear Spoiler Lip
- VW Euro Light Switch
- VW Euro Rear Headrests
- VW Euro 8” MIB2 Screen
- VW GTI Lighting Package Grille
- VW LED License Plate Lights
- WCT Performance Pedal Spacer
- WeatherTech Side Window Deflectors (F&R)
- Windows Down w/ Remote
- XDS Weak
- 3dcarstickers.com VW Center Cap Decals
- 18% Tint
Pending Install
- Audi S3 Aluminum Subframe
- Swoops Built Custom Brake Reservoir
- Swoops Built Custom Expansion Tank
Potential Future Upgrades
- Bosch 1300cc Injectors
- Built Motor
- EQT Brushless LPFP
- E85 Tune
Repairs to Date
- EVAP & Water Pump @ 24,325 miles
- Rear Wheel Bearings @ 42,309 miles
- Water Pump @ 63,618 miles
mk7_305
FL, USA
Dragy Times, Dyno Sheets, and Random Pics
Dragy Times
coming soon...
Dyno Sheets
Back when I was running an IS38 w/ APR Stage 2+ Tune:
Random Pics
Old setup - sooo dirty:
Old EFR7163 on the left, IS38 on the right:
A view from below during old EFR7163 install:
Some custom parts built by Swoops:
New rear bearings and rotors:
VL3X
Delaware
2017 GTI SE
Sounds like an awesome build. Can't wait to see pics! I assume it's tracked?
Jedimk7
In for a crazy build[emoji41][emoji106]
Sent from my Gavin Belson black box signature edition
GTI Jake
Charlotte, NC
Awesome build! The turbo heat blanket is the first I’ve ever seen on a car that looks aviation grade. Very clean all around from the little you’ve shown
