Mk7 SuperPro Strut Mounts
Cuzoe
Los Angeles
Sold!!!
Selling used SuperPro Fixed Camber Strut Mounts - SKU TRC5000 - $200
Price is pretty firm, will do $175 local pickup, willing to meet within an hour of SFV
Full disclosure: I bought them new, had them on the car for about less than 2 full tanks in my TDI, so somewhere under 1,000 miles. Removed because I (and two independent shops) could never get them to be silent for any extended length of time. My "adventures" with them are documented in various threads here and on Vortex, including my build thread. Anyway, after removing/installing about 5 times, making sure they were properly greased, torqued, etc... eventually they would develop minor noises with low speed turning, generally near steering lock.
There is NVH price to pay for increased camber and these are intended to keep NVH similar to stock... but it was not similar enough to be acceptable to me. No increase in vibration (as expected), some noise (mentioned above) but there is definitely added harshness. If it weren't for the low speed turning noise I wouldn't have removed them due to this harshness but back to back drives down the same roads showed a noticeable difference. I'm talking about poorly maintained/leveled roads and highways (I try my best to avoid potholes). I would also note that I had the 034 mounts installed prior and they had the same difference in harshness as compared to stock. Some claim no added harshness with either but solid aluminum is harder than plastic so the added harshness makes sense to me... your call on whether you notice and/or care.
Anyway, after 5-ish suspension combinations, somewhere around 10 sets of strut bearings (I replaced them every time I dropped the suspension, sometimes with less than 50 miles on them), I'm back on stock strut mounts, nice and quiet... the price is shipped in the US.
Cuzoe
Los Angeles
Pictures, and a bump... the black "gaskets" are just some roughly cut rubber sheet I tried at one point to reduce the added harshness. Didn't work... possibly too thin, or wrong choice of material, or just a silly idea, haha.
blaqsheep
Canada
IS38 GTI
What thickness did you use for the pad? I'll be installing different springs soon and wanted to see if adding a pad would help with the harshness as well, or just go with the Eurosport kit.
Cuzoe
Los Angeles
1/16" neoprene rubber sheet... I wasn't comfortable going any thicker. Adding a compressible material might also affect the torque required but I still torqued to factory spec. I never had any clunking or other sounds that suggested any problem with bolt torque, with or without the neoprene.
User KSR_808 (that might not be exact, going from memory) over on Vortex, in the Golf 7 R section, made a similar gasket for his install but I don't know if it was the same material (or if it worked).
blaqsheep
Canada
IS38 GTI
Yeah, I was just looking at that thread. I'll ask him what the verdict was. I'm torn between trying to find a solution to combat the harshness of metal on metal or just go with the Euro Sport inserts.
Didn't mean to jack your thread but was curious and these are really great mounts, hope you find a buyer!
