Ezekiel81923
- Royersford, PA
- 2019 Volkswagen GTI
If I'm paying to have my turbo installed is it a waste of $$ to get a new, calibrated waste gate actuator versus having the old one swapped over?
my spacer is the j-shape but the medium insert works for meI have a quick question and can’t seem to find the answer for it. I bought this o2 sensor spacer from emd and it came with adjustable inserts. I’m planing to put it on my IE downpipe but it didn’t provide any guidelines for which insert to use.
https://www.emdauto.com/products/ox...ith-adjustable-inserts?variant=42569634316547
Thank you, would there be any draw backs for using the most restrictive insert?my spacer is the j-shape but the medium insert works for me
it either works or it doesn't, and if it doesn't then you'll get a CELThank you, would there be any draw backs for using the most restrictive insert?
Less trial and error with the middle insert. If it works, you are all set. If you get the catalyst efficiency code, you need the more restrictive insert. If you get the rich/lean slow to respond code, you need the more open one. For what it's worth, I have an IE DP with a very similar straight spacer and the middle one worked for me.Thank you, would there be any draw backs for using the most restrictive insert?
I ended up uding the middle insert and drove about 200 km no code, seems like it worked. Thanks alot!Less trial and error with the middle insert. If it works, you are all set. If you get the catalyst efficiency code, you need the more restrictive insert. If you get the rich/lean slow to respond code, you need the more open one. For what it's worth, I have an IE DP with a very similar straight spacer and the middle one worked for me.
I have the AWE track as well, the drone reminds you that your car is not normal, and you get used to it.I had the AWE Track and finally decided to pull the trigger on a IE downpipe, OH GOD...
It sounds soo good but it drones soo hard, You guys think its worth getting that Vibrant 17950 res that many people talk about?
