El_bigote_AJ
- Las Vegas
- 2019 GTI bunny
You’re still fine either way , just keep the car under 3200ish rpms till you’re all good to goNon Flex Fuel. Got to switch ECU between E85 and 93.
What's a roof box? A hauler?
300-330whp, torque 350-380ish lbftEstimated hp/tq with full TBE/intake and stage 2 tune? Just like a rough range cause i’m starting to plan out my future build
will be getting the dsg tune as well through the AP and EQT, also have the intercooler in the works.. Would you say with the TBE and intake I should be “safe” in stage2 for a while or should I wait until I can get the other pieces as well300-330whp, torque 350-380ish lbft
also plan to upgrade mounts, intercooler, tires, clutch/dsg-tune etc
Depends. You'll probably want a dogbone insert at the very least. Power will suffer with stock intercooler but it'll be "safe". What tires are you currently running?will be getting the dsg tune as well through the AP and EQT, also have the intercooler in the works.. Would you say with the TBE and intake I should be “safe” in stage2 for a while or should I wait until I can get the other pieces as well
MPS4SDepends. You'll probably want a dogbone insert at the very least. Power will suffer with stock intercooler but it'll be "safe". What tires are you currently running?
