oddspyke
Delaware
2016 GTI, 2018 ZL1
And, generally speaking, on our cars the sweet spot is 20mm rear, 15mm front? What brands or sellers are recommended?
Yes, for totally flush. Any major brand hubcentric spacers are fine. ECS, urotuning, shopDAP and BMS all have complete kits with longer bolts (and wheel locks if you want them).
theglowpt3
Vancouver
What's the difference between activating Sport Mode by pushing the gear shifter down and using the infotainment system? Pushing the gear shifter down doesn't change the infotainment screen, but does add an "S" letter to my dash which indicates sport mode. Are these different modes or is the software just not written well? (2019 GTI btw).
edrex
NorCal
Different modes. The gear shifter changes shift points to keep rpms higher. The one in the infotainment changes a different set of options but I'm not too familiar with that one.
j_rad91!
Las Vegas, NV
2020 GTI
Since when is the GTI take 0W-20 oil? I bought the normal 5W-40 since this is my third GTI but apparently the 2019 is different. Should I not use this weight then and get the VW 0W-20? So irritating!
Strange Mud
Small Town CT
Assorted
I have noticed when I use the horn I must hit steering wheel buttons, I'll find the radio changed, MFD display different etc. Yesterday when someone pulled right in front of me I found I managed to reset the extended miles/mpg display. I didn't think this was possible w/o going through the radio. Anyone see this?
swcrow
7.5 GTI
If you follow that thread one member had a dealer monitor the variable timing component lock up and that cause his stalling.
This. BIG thread and many affected
