El_bigote_AJ
- Las Vegas
- 2019 GTI bunny
These are the optionsThat is True kinda weird there’s no android auto and I’m pretty sure China is huge on android auto so idk what vw was thinking.
@El_bigote_AJ does the RCD520 retain use of the factory usb port in the cubby? Or do you have to plug into the usb port on the face of the unit to get Carplay to work?These are the options
Face...it doesn’t have the rear mdi plug anymore unfortunately, my situation I was lucky cause I was able to use a 90 degree adapter then hook my wireless dongle to that and attach it to the back of my air ride controller mount so it’s all still hidden.@El_bigote_AJ does the RCD520 retain use of the factory usb port in the cubby? Or do you have to plug into the usb port on the face of the unit to get Carplay to work?
No, The slot on the front is the usb connectionDoes the RCD520 have an SD card slot?
Does it play lossless?
Lossless?
It all depends on the part number,not the car it is from
I've read all of the threads on this topic that I can find, I'm looking to upgrade my 2020 TSI to MIB2 and 8" screen. Is there any advantage to buying a 2GM035878A instead of the 2GM035844A it replaced? I haven't found any discussion of 2GM035878A anywhere. Would a new unit have any advantages over a used one? I have a dealer willing to remove CP.It all depends on the part number,not the car it is from
