applied all 3 stages from his instructions. works great for my 2019 golf and I do NOT have those two issues mentioned in the OP stated. link below and I also copied his instructions here. I used VCDS instead of OBD11. you only modify the red part. you use the keyword in blue to search in adaption.
https://www.reddit.com/r/GolfGTI/comments/a910bh/euro_taillight_mod/
-------------- instruction quote -----------------------
Coding for this mod is below. I have it in 3 stages, the first one being the most visually safe and getting less safe as it goes down. I wouldn't recommend doing the last two because (1) the tail lights are mostly invisible during the day and (2) having the whole brake/tail light go dark at night might not be something you want. But hey it's your car so...
The module in question is 09 - Central Electrics. Go into its Adaptations.
All modified values have a "***" before and after them.
(Stage 1) Enable outer tail lights/running lights (Schlusslicht) as turn signals:
Leuchte23SL HLC10 (Outer SchlussLicht/running light, left):
Lasttyp 23: 43 - allgemeine LED
Lampendefektbitposition 23: a
Fehlerort mittleres Byte DTC-DFCC 23: 29
Lichtfunktion A 23: Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
*** Lichtfunktion B 23: nicht aktiv --> Blinken links Hellphase ***
Dimmwert AB 23: 127
Lichtansteuerung HD AB 23: always
*** Lichtfunktion C 23: nicht aktiv --> Blinken links Dunkelphase ***
Lichtfunktion D 23: nicht aktiv
Dimmwert CD 23: 0
*** Dimming Direction CD 23: maximize --> minimize ***
Lichtfunktion E 23: nicht aktiv
Lichtfunktion F 23: nicht aktiv
Dimmwert EF 23: 0
Dimming Direction EF 23: maximize
Lichtfunktion G 23: nicht aktiv
Lichtfunktion H 23: nicht aktiv
Dimmwert GH 23: 0
Dimming Direction GH 23: maximize
Leuchte24SL HRA65 (Outer SchlussLicht/running light, right):
Lasttyp 24: 43 - allgemeine LED
Lampendefektbitposition 24: 1a
Fehlerort mittleres Byte DTC-DFCC 24: 2a
Lichtfunktion A 24: Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
*** Lichtfunktion B 24: nicht aktiv --> Blinken rechts Hellphase ***
Dimmwert AB 24: 127
Lichtansteuerung HD AB 24: always
*** Lichtfunktion C 24: nicht aktiv --> Blinken rechts Dunkelphase ***
Lichtfunktion D 24: nicht aktiv
Dimmwert CD 24: 0
*** Dimming Direction CD 24: maximize --> minimize ***
Lichtfunktion E 24: nicht aktiv
Lichtfunktion F 24: nicht aktiv
Dimmwert EF 24: 0
Dimming Direction EF 24: maximize
Lichtfunktion G 24: nicht aktiv
Lichtfunktion H 24: nicht aktiv
Dimmwert GH 24: 0
Dimming Direction GH 24: maximize
(Stage 2) Enable inner tail lights/running lights (Schlusslicht) as turn signals:
Leuchte16BLK SLB35 BLK SL KC9 (Inner tail light, right)
Lasttyp 16: 43 - allgemeine LED
Lampendefektbitposition 16: 0
Fehlerort mittleres Byte DTC-DFCC 16: 36
Lichtfunktion A 16: Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
*** Lichtfunktion B 16: nicht aktiv --> Blinken rechts Hellphase ***
Dimmwert AB 16: 127
Lichtansteuerung HD AB 16: only_if_closed
*** Lichtfunktion C 16: nicht aktiv --> Blinken rechts Dunkelphase ***
Lichtfunktion D 16: nicht aktiv
Dimmwert CD 16: 0
*** Dimming Direction CD 16: maximize --> minimize ***
Lichtfunktion E 16: nicht aktiv
Lichtfunktion F 16: nicht aktiv
Dimmwert EF 16: 0
Dimming Direction EF 16: maximize
Lichtfunktion G 16: nicht aktiv
Lichtfunktion H 16: nicht aktiv
Dimmwert GH 16: 0
Dimming Direction GH 16: maximize
Leuchte17TFL R BLK SRB3 TFL R BLK SR KC3 (Inner tail light, left)
Lasttyp 17: 43 - allgemeine LED
Lampendefektbitposition 17: 0
Fehlerort mittleres Byte DTC-DFCC 17: 35
Lichtfunktion A 17: Standlicht allgemein (Schlusslicht, Positionslicht, Begrenzungslicht)
*** Lichtfunktion B 17: nicht aktiv --> Blinken links Hellphase ***
Dimmwert AB 17: 127
Lichtansteuerung HD AB 17: only_if_closed
*** Lichtfunktion C 17: nicht aktiv --> Blinken links Dunkelphase ***
Lichtfunktion D 17: nicht aktiv
Dimmwert CD 17: 0
*** Dimming Direction CD 17: maximize --> minimize ***
Lichtfunktion E 17: nicht aktiv
Lichtfunktion F 17: nicht aktiv
Dimmwert EF 17: 0
Dimming Direction EF 17: maximize
Lichtfunktion G 17: nicht aktiv
Lichtfunktion H 17: nicht aktiv
Dimmwert GH 17: 0
Dimming Direction GH 17: maximize
(Stage 3) Disable brake lights acting as turn signals:
Leuchte20BR LA71: Brake light, left
Lasttyp 20: 43 - allgemeine LED
Lampendefektbitposition 20: 13
Fehlerort mittleres Byte DTC-DFCC 20: 3d
Lichtfunktion A 20: Bremslicht
*** Lichtfunktion B 20: Blinken links Hellphase --> nicht aktiv ***
Dimmwert AB 20: 100
Lichtansteuerung HD AB 20: always
*** Lichtfunktion C 20: Blinken links Dunkelphase --> nicht aktiv ***
Lichtfunktion D 20: nicht aktiv
Dimmwert CD 20: 0
*** Dimming Direction CD 20: minimize --> maximize ***
Lichtfunktion E 20: nicht aktiv
Lichtfunktion F 20: nicht aktiv
Dimmwert EF 20: 0
Dimming Direction EF 20: maximize
Lichtfunktion G 20: nicht aktiv
Lichtfunktion H 20: nicht aktiv
Dimmwert GH 20: 0
Dimming Direction GH 20: maximize
Leuchte21BR RC8: Brake light, right
Lasttyp 21: 43 - allgemeine LED
Lampendefektbitposition 21: 23
Fehlerort mittleres Byte DTC-DFCC 21: 3e
Lichtfunktion A 21: Bremslicht
*** Lichtfunktion B 21: Blinken rechts Hellphase --> nicht aktiv ***
Dimmwert AB 21: 100
Lichtansteuerung HD AB 21: always
*** Lichtfunktion C 21: Blinken rechts Dunkelphase --> nicht aktiv ***
Lichtfunktion D 21: nicht aktiv
Dimmwert CD 21: 0
*** Dimming Direction CD 21: minimize --> maximize ***
Lichtfunktion E 21: nicht aktiv
Lichtfunktion F 21: nicht aktiv
Dimmwert EF 21: 0
Dimming Direction EF 21: maximize
Lichtfunktion G 21: nicht aktiv
Lichtfunktion H 21: nicht aktiv
Dimmwert GH 21: 0
Dimming Direction GH 21: maximize
Also this but I didn't notice anything different when changed to No:
Aussenlicht_Heck:
Bremslicht_ist_auch_Blinklicht: Yes --> No (Brake lights are also turn signals)
Leuchte12NL LB45 = left fog light
Leuchte13NL RB5 = right fog light
Leuchte16BLK SLB35 BLK SL KC9 = right inner tail light
Leuchte17TFL R BLK SRB3 TFL R BLK SR KC3 = left inner tail light
Leuchte20BR LA71 = left brake light
Leuchte21BR RC8 = right brake light
Leuchte22BR MA57 = 3rd brake light
Leuchte23SL HLC10 = left outer taillight
Leuchte24SL HRA65 = right outer taillight
Leuchte25KZL HA59 = both license plate lights
Leuchte26NSL LA72 = both front orange/amber marker lights
Leuchte27NSL RC6 = both rear red marker lights
Leuchte28RFL LC11 = left reverse light
Leuchte29RFL RA64 = right reverse light
Leuchte30FR LC72 = footwell lights
Leuchte6ABL LC5 = left dipped beam / low beam
Leuchte7ABL RB1 = right dipped beam / low beam
Leuchte8FL LB39 = left high beam
Leuchte9FL RB2 = right high beam
Dimmwert AB 23: 127
Dimmwert CD 23: 0
Dimmwert EF 23: 0
Dimmwert GH 23: 0
Dimmwert AB 24: 127
Dimmwert CD 24: 0
Dimmwert EF 24: 0
Dimmwert GH 24: 0
Dimmwert AB 16: 127
Dimmwert CD 16: 0
Dimmwert EF 16: 0
Dimmwert GH 16: 0
Dimmwert AB 17: 127
Dimmwert CD 17: 0
Dimmwert EF 17: 0
Dimmwert GH 17: 0
Dimmwert AB 20: 100
Dimmwert CD 20: 0
Dimmwert EF 20: 0
Dimmwert GH 20: 0
Dimmwert AB 21: 100
Dimmwert CD 21: 0
Dimmwert EF 21: 0
Dimmwert GH 21: 0
Aussenlicht_Heck:
