CosmosMpower
- Dallas, TX
Wife bumped into someone at a light, low speed 10 mph or less, no paint damage to any panels, no airbags deployed, truly a low speed bump. The impact cracked the front upper grille right at the VW badge and seemed to push the hood back towards the windshield a bit. Took it to a shop and they were able to adjust the hood mostly back into position but on the driver side they can't get the grill to sit down into the top of the bumper because the headlight too tight up against the edge of the grill. There is also a gap between the bottom edge of the headlight and the bumper.
They are guessing the radiator/core support is cracked and must have buckled in a bit somewhere on the driver side (even though the impact was dead center). They want a good bit of money for mechanical labor to replace the radiator support so I wanted to get some opinions from the board to see if it's likely that would cause a misalignment of all the parts. Right now when the hood is closed it overhangs the headlight and center grill a bit like that corner is sunken in a little.
Is there any adjustability in how far the headlight or core support sits?
They also replaced the radiator support air deflector that the bumper clips into but there's still a gap between the bumper and headlight.
Pics: https://photos.app.goo.gl/tbuoaVU7dHp7v3859
