Blaupunkt 8" Powered Subwoofer
Yesterday I installed my new Blaupunkt powered subwoofer under the driver's seat. I wanted a little more low end bump that the Fender Audio System was lacking.
Things you need for the install:
- Trim Removal Tool
- Add-A-Fuse
- Wire Stripper or Small Knife
- Black Electrical Tape
- Needle Nose Pliers
- Torx Screwdriver Set
Quality: The subwoofer is sturdy and has a lot more heft to it than one would think. It's probably about 12 pounds, easily carried in one hand. I's encased all in metal and there's a protective grille that I didn't have too high hopes for but actually is pretty nice and sturdy. I would feel comfortable if a grocery bag or carryon bag fell on it, no problem.
The included wiring harness has double of everything (power, ground and left and right channels) and has a good amount of cable to use. I mounted it under my seat and was able to route it completely to the glove box and still had about a foot of slack to work with.
Audio Quality:Impressive. I didn't expect a lot from this but it definitely blew me out of the water. It's adjustable to wether you want punchy bass or boomy bass. I hooked it up directly to the Fender Subwoofer (why is it so small?) so whenever I adjust the subwoofer in the headunit, it also changes the powered subwoofer.
I set my crossover and phase right in the middle and adjusted my volume about 65%. I found that I can set my subwoofer setting in the sound menu to 9 and only on really boomy bass songs will the subwoofer start to shake, it doesn't clip but the subwoofer wasn't made for that low of frequencies that it is too much. This subwoofer can definitely provide more than enough power for those looking for more bass without wanting to add the traditional subwoofer box and amplifier combo.
Wiring:First off, I ran the red power cable under the seat under the rails and tucked it under the sills and into the fuse box. You can also tuck it under the weather stripping and both cables fit just fine and aren't pinched when the door is closed.
I then used an
add-a-fuse to tap into where the bottom yellow 20A fuse is. That's the fuse for the 12v sockets in the car. You can set your sockets to be live all the time by moving the 20A fuse one spot up in it's location. Keep in mind that if you do this you can't leave things such as chargers plugged into the 12v socket because it will drain your battery. The subwoofer is fine because it won't turn on until it picks up an audio signal.
I'll take some more pictures later when I get into the car again, I'll show exactly how the add a fuse looks, I was so confused trying to figure out how it goes. Keep in mind I ran both red power wires but only connected one.
For the ground and the rest of the gray and white wires, I first stuck them under the mat.
Then routed them up towards the side of the rear seat and towards the rear of the vehicle and under the spare tire cover. I will later tuck the wires showing under the seat, I did this install in my a parking garage with basic electrician tools.
(This is where the edge of the rear seat meets the pillar trim.)
After that we get to the Fender Audio subwoofer
It is enclosed under a plastic cover that is screwed in by 4 Torx screws. Don't know the exact size but it's about a T15 or T20 if I was to guess. Anyways, lift the subwoofer out and flip it upside down exposing the leads.
I took out the black prongs/clip things with some needle nose pliers and put the white wires inside the clips and put them back into place. To make sure i connected them correctly, I turned the car on, which should turn on a green light on the subwoofer and tested the wires in different locations to see which one worked. After you get yours in, replace the subwoofer and it's cover.
After that is done you have the ground left to do. You can put that on any bolt in the car, the closest being the seat bolts. I ran mine to the trunk with my gray and white wires and found some bolts on either bottom corner of the trunk. Put your ground in and your done.
Adjust your your volume, crossover and phase knobs to your liking and enjoy your subwoofer.
