This is the current scan, not sure if it sheds any light? Any help apricated
Address 19: CAN Gateway (J533) Labels
5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 F
Component: GW MQB High 128 1244
Revision: -------- Serial number: 0004366095
Coding: 030100041F087300FB00027E1D0F0001000105000000000000 0000000000
Shop #: WSC 131071 1023 2097151
ASAM Dataset: EV_GatewLear 013020
ROD: EV_GatewLear_013.rod
VCID: 79BA0FFAF8468787E0-802C
Alternator:
Multi Function
Steering Wheel Control Module:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29150002507410025521
Coding: 2DFFFF
Battery Monitoring Control Module:
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 8579118603
2 Faults Found:
66052 - Infotainment CAN Bus (SAE Bus E)
U0065 00 [008] - Performance
[Globaler Timeout CAN-Infotainment]
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 215
Mileage: 128911 km
Date: 2020.02.13
Time: 14:57:55
Supply voltage: Terminal 30: 12.4 V
Terminal 15: OFF
15360512 - Component Protection
U1101 00 [009] - Active
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 153
Mileage: 127833 km
Date: 2020.01.31
Time: 09:59:58
Supply voltage: Terminal 30: 12.2 V
Terminal 15: On
Address 5F: Information Electr. (J794) Labels:* None
Part No SW: 5NA 035 020 D HW: 5NA 035 020
Component: MU-H-ND-EU H55 1367
Serial number: A845B0JS034120
Coding: 02730001FF00000051111101008808101F0102C601200500FF
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_VW37.rod
VCID: 3228F8D665B0B4DF61-8066
Operating And Display Unit 1:
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H52 9130
Serial number: VWZ6ZJV1901385
Data medium:
Subsystem 2 - Part No SW: V03 959 800 QS HW: -----------
Component: ECE 2018 --- 0166
Serial number: --------------------
Compact Disc Database:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1017
2 Faults Found:
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 175
Mileage: 128911 km
Date: 2020.02.13
Time: 15:40:51
Voltage terminal 30: 12.1 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
15360768 - Component Protection
[Anti-theft protection - component protection active (0xEA6300)]
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 175
Mileage: 128911 km
Date: 2020.02.13
Time: 15:40:51
