El_bigote_AJ
- Las Vegas
- 2019 GTI bunny
Hi Guys,
I'm going to be install a meth injection kit this weekend and I'm trying to weight out my fail safe options. the kit I'm using is from AEM and their controller does have a signal beyond the dummy light that gets triggered when there is some issues, I initially wanted to use the system by just adding the FSB from Burger since Im jb4, but per George the AEM kit wont work with their FSB and I'm not going to be JB4 for much longer so i will still need a stand alone option.
what have others done as fail safes?
I was thinking of grassroots type concept using a normally closed solenoid with a relay between that and the boost safety signal that would then be connected to a boost tap line (not sure it that's even big enough to let off enough boost pressure quick enough) or welding a 1/2' or 1/4" bung to the charge pipe.
but maybe there is better options that have been done, ideally it would be great to have it built into a tune to throw the car to a safety map but i don't know if our tuning options for our platform have something like that.
I'm all ears
I'm all ears
