AlienSP
- Austin, TX
Any updates on the new IS38x? I've been traveling and maybe missed something along the way.
Thanks arob and Mr. Badass; seems like I'm the last to know or not keepin' my eye on the ball around here. Switching job locations soon so it's Charlotte area or W. Wisconsin. Colder air, but probably 91 oct. areas. Still interested in the"38".
It is tough with Littco and seems to be because Dan is so darn busy, is always trying to make improvements, and release new products.
I placed my order for the L380X supercore today, and hope to get it in next month (got some mods backed up currently). Hoping to be able to hit 390-400whp with the larger compressor wheel and max & hold power out past 6000rpm. If a HPFP will be able to hold out to 6500rpm on e50 and I will be a happy camper.
Depending on where you end up, Wisco should have a decent ethanol supply. It is a big state though.
Did you order through their website? Couldn't find any IS38/L380 etc. on there.
On a side note: Anyone here running them on APR's IS38 map? Interested in throwing one onto the 1.8l Wagon. No other supporting mods needed besides DP/Intercooler right? Looking to just make numbers similar to standard IS38, just want it to be stout.
I had seen a previous post (from someone) that had sent a core/CHRA to Littco for rebuild and that they also had a new offering. I inquired about both via Facebook Messenger and received a reply in 24 hours.
The options were an IS38 core rebuild (aka the IS38X core/CHRA with upgraded journal bearing assembly and clipped turbine wheel with stock com) or an L380X Supercore (upgraded journal bearing assembly, clipped turbine wheel, and larger compressor wheel + modified compressor housing. Just bolt up your old turbine housing and DV/WG actuator and go).
Did Dan give you any specs on the upsized compressor?
He didn't specify. I would imagine it is a modest increase. Stock is 45.2mm. The L430 spec he listed online is 50mm. I am guessing it is probably between the stock 45.2mm wheel and a 48mm wheel. Again it does come with a modified compressor housing, so it is definitely larger. Pretty sure the larger wheel eliminates some surge at the ever so slightest expense of spool, but probably picks up on the top end well.
I will reach out an ask what the exact spec is, or maybe ask Dan to comment here if he has a chance.
