@Acadia18
Buying new components & finding they are faulty I feel your pain!!...
I build my own computers, & tend to keep them a long time, resulting in them being “updated” in their lifespan. My current “Win10 Pro 64bit” computer I built back in 2015yr, (the power unit & Graphics card are actually older as they came out of the previous computer) & decided to give it a “refresh” with the Christmas sales. In fact I was going to do this just before the pandemic hit, but then the prices of parts went through the roof, so I left it until now!
I run “slow” WD “Black” spinny disc HDD in my computers & for external back-ups. I did try an SSD (Sandisk) in my laptop a few years ago, but it failed (out of warranty). The reason being I don’t use the laptop much, mainly for VCDS, so the long-term lack of voltage is known to cause the controllers to FUBAR!!
Anyway, as my 2015yr desktop PC had an unused M.2 slot (yes an older PCIe3 speed version) I ordered direct from the “brand” website a Crucial “T-500” 500GB PCIe4 NVMe & a Crucial “MX500” 1TB 2.5inch SATA SSD.
I then set about the install & swapping, in stages!
Now the “old” set-up was OS on one HDD, documents & photos etc on a different HDD, with Music on a different HDD, & another HDD acting as the daily internal back-up. This meaning there were 4x spinny disc HDD in the case!!
Now NVMe requires GPT, & not MBR, & the BIOS of the Mobo has to then be changed from “legacy” to UEIF. Cue lots of BIOS alterations, & testing, checking, initialising/formatting etc of the new NVMe drive. Once I was happy it worked I then used EaseUS Todo, & also their Partition Master (both the paid for versions) & converted the existing HDDs to GPT. Once I had done that I made new back-ups & then cloned the OS onto the new NVMe. (I decided against a fresh install as re-downloading over my internet connection & reinstalling all the drives I wanted to avoid!)
After runing the OS on the NVMe for a day & having done various tests etc., it was time to do the same for the SSD. So install it, check BIOS that it appears correctly, & load up windows…..cue trouble!!....It FUBAR’d the computer, & fecked up the SATA controller which basically ditched all the other SATA drives that were plugged in! So I did a forced shut-down, uninstall the SSD, & the computer now works ok. So install the SSD in an external USB3 case, so it won’t feck up the computer, & basically the SSD can’t be “initialised”. Also checked it by plugging the external case into my laptop & the same results! Used the various tools to check the SMART data & its showing
ID5, Reallocated NAND block count = 1 NAND blocks
ID174, Unexpected power loss count = 5 Unexpected power loss events
ID187, Reported Uncorrectable errors = 71 ECC correction failures
So I emailed Crucial & got an RMA from Crucial, but they state that I had to send the item back to them insured. Ok not a major problem. But then they stated that the replacement item would be coming from their EU warehouse I might be hit with incoming customs fees!!. So I just sent it back demanding a refund, ..feck paying customs!
I then ordered a Samsung 870EVO 1TB SSD, for the similar price, which happened to have a much higher TB write warranty! Anyway I got everything swapped over OK, & "touch wood" everything still works all ok!
I was unfortunate with the Crucial SSD, as them, Sandisk/WD, & Samsung are the best & there is always a small % failure rate chance! Just the customer service “returns charges” that I would have to pay out because they don’t keep stock in the UK…feck that!!...
So now I have a computer which even with a “slow” BIOS boot (if set to “fast” it’s impossible to react quick enough to get into the BIOS) can go from total off to full working in 50secs!!...This when it was circa 5mins!!!....Apparently GPT is faster at loading than MBR, which also helps.
Also, as I now have the OS on the NVMe, with all documents/photos/music on the single SSD, I then reused 2x of the old WD Blacks, as internal back-ups.
Photo below of the inside...nothing fancy, no LED lights, just gets on with the work!
